Topic: Mission Planner "check port settings or port in use" Firmware Error (Read 4837 times) previous topic - next topic
ryner
I've got an Arduino Uno R3 board
And here's whats happening:
1: I'm connecting my Arduino to my pc via USB
2: I run MissionPlanner (the Latest version)
3: I select the "Initial Setup" tab in mission planner > Install Firmware > then i select the Firmware: ArduCopter V3.1 Quard
4: It asks me "Is this an APM 2+" i select no and then after it "detects board" i get this error "check port settings or port in use" and a whole lot of other stuff as shown in this image below:
Any Ideas?
Thanks
---Ryner
spycatcher2k
Does it work in the arduino IDE? if it does then you would be better contacting the maker of the program, or using there forum. If not, have a look at the COM ports on your system (device manager) and see what one is added when you plug in your R3
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
K5CZ
Access to the port COM3 is denied means, that the port is used by another running application. Close all other applications or reboot the computer.
ryner
Thanks for the reply, Yes it does work in the IDE...100% functioning in the IDE
I confirmed that COM3 is the correct port that my Arduino R3 is connected to.
Also, do you think i'm doing anything wrong?
my setup is pretty much just the Arduino board connected via USB with no components, no motors no nothing connected to it.
Is this right?
ryner
Thanks for the post
I tried closing all other Applications, but nothing seems to solve my error
I can't upload a firmware to my Arduino, Nor can I click "Connect" in mission planner
---Ryner
K5CZ
So, it is time to try another terminal program to connect. My favorites are:
Termite
CoolTerm
Also you may try to use PuTTY, but this way is little hardcore ;-)
caringbrasil
Hi guys! I am having the same problem.
I have a GPS module hooked in to my Arduino but when I try to connect to Mission Planner, the connection fails.
Somebody knows if it is impossible to connect Arduino Uno to the Mission Planner, or anybody have another idea of how to get GPS telemetry data into a Ground Station using Arduino (Any Arduino), not a ArduPilot, because it's for skydive not drone?
Best regards, Thiago Renan da Costa.
