Topic: Unexpected output when converting to an integer with int() (Read 5212 times) previous topic - next topic
_mjw_
Just beginning with arduino and am writing code to display a binary counter with diodes.  I realize that one could simply use bitRead(count,b) to extract the bth bit of the counter count, but on the way, I have tried
count & int(pow(2,b)).   Converting 2b to integer is yielding some unexpected results.
The output was sent to the Serial Monitor.
Here is the code:
  int index;
  for (int k=0; k<=7; k++) {
    float m = pow(2,k);
    int q = int(m);
    Serial.print("m = ");
    Serial.print(m);
    Serial.print("\t q = ");
    Serial.println(q);
This is the output:
m = 1.00    q = 1
m = 2.00    q = 2
m = 4.00    q = 3
m = 8.00    q = 7
m = 16.00   q = 15
m = 32.00   q = 31
m = 64.00   q = 63
m = 128.00  q = 127
Any ideas on why this is happening?  Perhaps int() is rounding down?
Thank you!
_mjw_
Ah, p. 77 in the Arduino Cookbook states that when casting  to an integer, floating-point numbers do not round correctly.  It seems that 2^4 comes up with something a little less than 16.00 and when cast as an integer,  int(16.00 - a_tiny_bit) = 15.
Very unexpected!
PaulS
Floats are NOT rounded when converted to ints. They are truncated.
Very unexpected!
Not by me.
holmes4
_mjw_
Very unexpected!
Not by me.
Okay.  If the expected behavior is to truncate, then yes, it is working.  I was (and am) still surprised to find
that 2^4 < 16.0.  (Probably better would be to use bitshift left  (1<<4) and keep everything always integer).
ALL integer maths "rounds" down. Try 3/2
And   -3/2  results in  -2.  Seems that if we want to round rather than truncate, we should add 1.0/2.0
before casting as integer, yes?
Thank you both for the helpful comments!  It has been years since programming in C and it will be nice to become familiar again with details like these ...
mrburnette
... and if you programmed on a PC or minicomputer in C, then C++ for microcontrollers is even more distant.
Underneath the Arduino GUI is the AVR GCC compiler:
http://www.avrfreaks.net/wiki/index.php/Documentation:AVR_GCC#Getting_started_with_AVR-GCC
There is also the AVR-LIBC library that is available:
http://www.nongnu.org/avr-libc/
and use with Arduino introduced here:
http://arduino.cc/en/Reference/UsingAVR
Things to keep in mind:
  • You can generally swing between Arduino'ish commands and C++ commands
  • You can resort to extern C {} or you can do inline assembler as advance coding.
The compiler does a tremendous amount of optimizations ... sometimes taking out some of your code or even rearranging it.  Never assume.  If you really want to know what happened, you can get the assembler source with just a little work.
IF you are using Windows, you can also get information on the Flash and SRAM usage of your code with a little scripting:
(adjust paths are required)
PATH=%path%;C:\Program Files\Arduino_105\hardware\tools\avr\utils\bin;
CD %TEMP%
MD %PUBLIC%\ELFtemp
for /R %TEMP% %%f in (*.elf) do XCOPY /D /Y %%f %PUBLIC%\ELFtemp\
DIR %PUBLIC%\ELFtemp\*.elf /s /b /O:-D /T:W >ElfRhere
SET /P ELF= <ElfRhere
ECHO %ELF% >MemUsage.txt
AVR-SIZE -C %ELF% >>MemUsage.txt
NOTEPAD MemUsage.txt
SET ELF=""
Ray
_mjw_
Actually, since then a little bit with Linux, but mostly on a SPARC (Unix) !
Thank you very much!  Should keep me busy for a while!
Very nice!  Hope to learn about this too!
May be a reason to check out windows ...,  wonder if it can also be done on a Mac?  A very quick online search
seems to show that it can (again, Arduino Cookbook, Chap. 17).
Thank you for all the suggestions.  Looking forward to reading about all of this!
mrburnette
By polypagan for Linux:
Not tested, but my bash script should also work just fine on MacOS (in terminal, of course).
http://forum.arduino.cc/index.php?topic=196101.msg1450173#msg1450173
michinyon
Very unexpected!
That's not unexpected at all.  All computers work that way.
_mjw_
Not all.
The following C code (OS X 10.8.5, gcc) produces expected output:
#include <stdio.h>
#include <math.h>
main()
  int index, k, q;
  float m;
  for (k=0; k<=7; k++) {
    m = pow(2,k);
    q = (int) m;
    printf("m = %f",m);
    printf("\t q = %d\n",q);
Here is the resulting output:
m = 1.000000    q = 1
m = 2.000000    q = 2
m = 4.000000    q = 4
m = 8.000000    q = 8
m = 16.000000   q = 16
m = 32.000000   q = 32
m = 64.000000   q = 64
m = 128.000000  q = 128
Could someone please explain why the Arduino produces different results?
Thank you!
_mjw_
32 bit float vs. 64 bit float
Recompiled with the option -m32 (to enforce 32 bit calculations) and got the same results!
mrburnette
Thank you
Isn't the real question, what happens with Atmel Studio on a naked 328P with all the latest packages?
The issue may just be with the AVR-GCC math library.  Arduino does not package the latest version of AVR-GCC, so we could be looking at an already "fixed" issue.
Things like this can get under ones skin... When in college years ago, I was dismayed to find my TI scientific calculator would not answer 0 to sin(45) - cos(45) while the dude that sat across from me had an HP and it did give 0.  Needless to say, my anal self sold the TI and bought an HP67... And never looked back!
Ray
SirNickity
In general, it's best to avoid floats anywhere you can use integers.  For one, go browse the avr-libc handbook, particularly the math stuff.  You'll find a lot of it uses floats as parameters by default.  Since there's no floating-point hardware in an AVR mega or tiny, that all has to be done via software emulation, which is extra code bloat that you probably didn't need for your intended application.
For that reason, be aware of the math functions you use and try to implement them in more efficient ways if you can.  E.g., definitely use shifts to do powers of 2.  You'll get a more accurate result, it'll execute faster (a relative term), and assuming you don't use floats anywhere else, it'll save all the flash space required to include the fp math library.
Naturally, when you need non-integer values and can't get by with fixed-point math, well ya godda do whatcha godda do.  And none of this applies in test cases and matters of curiosity like in this thread.
_mjw_
Not sure.  Haven't tried Atmel Studio.  Is that an application only for windows?
Thank you for suggesting it may be something with the AVR-GCC math library.  Don't think I'll have time to compare the latest version to whatever is implemented in the Arduino software (am simply using the Arduino project Version 1.0.5) .
Looks like I was not the first one surprised by this!  Check out this link:
http://8515.avrfreaks.net/index.php?name=PNphpBB2&file=printview&t=80319&start=0
Things like this can get under ones skin [...] bought an HP67... And never looked back!
The HPs are nice calculators!
