Topic: Override attachInterrupt() (Read 2017 times) previous topic - next topic
aureliusss
Jan 07, 2014, 12:32 pm Last Edit: Jan 07, 2014, 12:36 pm by aureliusss Reason: 1
Hi everyone,
I'm working on an Arduino Due custom board and i need to use interrupts on other pins not numbered on the orginal board.
Thus i rewrited the attachInterrupt function in this way:
Code: [Select]
void attachInterrupt(Pio* pPio, uint32_t dwMask, void (*callback)(void), uint32_t mode)
static int enabled = 0;
if (!enabled)
__initialize();
enabled = 1;
uint32_t pos = 0;
uint32_t t;
for (t = dwMask; t > 1; t >>= 1; pos++);
// Set callback function
if (pPio == PIOA) callbacksPioA[pos] = callback;
if (pPio == PIOB) callbacksPioB[pos] = callback;
if (pPio == PIOC) callbacksPioC[pos] = callback;
if (pPio == PIOD) callbacksPioD[pos] = callback;
// Configure the Interrupt mode
if (mode == CHANGE)
// Disable additional interupt mode (detects both rising and falling edge)
pPio -> PIO_AIMDR = dwMask;
// Enable aditional interrupt mode
pPio -> PIO_AIMER = dwMask;
if (mode == LOW)
pPio -> PIO_LSR = dwMask;       // Level select register
pPio -> PIOFELLSR = dwMask;     // Falling edge/ Low level Select Register
if (mode == HIGH)
pPio -> PIO_REHLSR = dwMask;  // Rising Edge High Level Select Register
if (mode == FALLING)
pPio -> PIO_ESR = dwMask;     // Edge select register
pPio -> PIO_FELLSR = dwMask;  //Falling Edge Low Level Select Register
if (mode == RISING)
pPio -> PIO_ESR = dwMask;      //Edge Select Register
pPio -> PIO_REHLSR = dwMask;   //Rising Edge High Level Select Register
//Enable Interrupt
pPio -> PIO_IER = dwMask;
My first try has been to override the function, but when compiling it tells me that the two functions do conflict.  is there anything wrong in the code i wrote?
i did anything but allowing attachInterrupt to be used declaring Port e bitmask to select the rught pin
graynomad
You can't just write another function with the same name unless the original is declared as "weak", which I doubt is the case with attachInterrupt().
Why not just use your own function name?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
MarkT
You can't override a function, only a method.  Methods belong to a class, a sub-class can
override method implementations, but functions are global and unique.
aureliusss
OK, then i added a new function in WInterrupts.h/.c implemented like this:
Code: [Select]
void _attachInterrupt(Pio* pPio, uint32_t dwMask, void (*callback)(void), uint32_t mode)
if (!enabled)
__initialize();
enabled = 1;
uint32_t pos = 0;
uint32_t t;
for (t = dwMask; t > 1; t >>= 1, pos++);
if (mode == CHANGE)
if (mode == LOW)
pPio -> PIO_FELLSR = dwMask;     // Falling edge/ Low level Select Register
if (mode == HIGH)
if (mode == RISING)
//Enable Interrupt
just the same as the orginal attachInterrupt(), the only difference stays in the fact that i can directly pass PIO port and BitMask to use a pin not declared in variant.h (I need to attach an Interrupt to PIOB3, one of the ethernet pins).
Of course this is not working, or at least it make the code to get stucked:
this is the working code:
Code: [Select]
volatile boolean off = false;
  Serial3.begin(115200);
  delay(20);
  init_motor_pins();
  pmc_enable_sleepmode(0);
  if (off)
    off = false;
   //Set OUT_CPU pin LOW
    PIOB -> PIO_CODR = OUT_CPU_BM;
  for (uint8_t k = 0; k < 28; k++)
    value[k] = readCapacitivePin(k);
    //    Serial3.println(value[k]);
  //Serial3.println();
    if ((value[k] > edge[k] + range) & (pressed[k] == 0))
      //Serial3.print("TOCCATO ");
      //Serial3.println(k);
      touched(k);
      pressed[k] = 1;
    if ((value[k] <= edge[k]) & (pressed[k] == 1))
      //Serial3.print("RILASCIATO ");
      pressed[k] = 0;
  if (Serial3.available())
  { //change Serial3 to Serial31 if using BT
    char lettera = (char)Serial3.read();
Serial.print(lettera);
void _off()
delay(5);
off = true;
if add my _attachInterrupt() function in the setup everything stop working:
Code: [Select]
  delay(20);
  init_motor_pins();
_attachInterrupt(PIOB, IN_CPU_BM, _off, LOW);
do you have any idea of what could be happening and why the code it's not working anymore?
aureliusss
with a couple of printing i saw that it stops right when _attachInterrupt is called. It does not go further! How come?
aureliusss
replacing my version  _attachInterrupt() with the original attaInterrupt() does not change how the code works. it just stops as soon as i call the function in the setup.
has anyone ever meet this kind of problem?
MarkT
I presume you've understood the relevant parts of the SAM3X8E datasheet and the
existing attachInterrupt code?  Its a significantly more complex chip to interface to
than the ATmega's, you have to be careful and methodical.
graynomad
I'm not familiar with the SAM regs, but what's in __initialize();? You should post that as well for those who are. There is real potential for a screw up in there I would think.
And why do all 4 interrupts get the same callback func?
______
Rob
aureliusss
__initialize() function is explained in WInterrupts.h/.c
