Topic: Atmega165 on Arduino IDE (Read 839 times) previous topic - next topic
Einherj
Jan 07, 2014, 09:26 pm Last Edit: Jan 07, 2014, 09:29 pm by Einherj Reason: 1
I've been trying to find out if anyone has used the Atmega165 on the Arduino environment. So far there's been little to no luck.
The only thing kind of close I found was this forum post which suggests someone has made a core for this chip...
http://forum.arduino.cc/index.php?topic=106237.0
...but in the package the Xboards.txt which has the atmega165 entry references to a bootloader called bf_boot.hex which I could not find in the package. Also, I don't think "atmega165" is defined in any other file than this. Am I missing something here?
Code: [Select]
arduino_atmega165.name=Arduino-Atmega165
arduino_atmega165.upload.protocol=stk500
arduino_atmega165.upload.maximum_size=14336
arduino_atmega165.upload.speed=57600
arduino_atmega165.bootloader.low_fuses=0xE2
arduino_atmega165.bootloader.high_fuses=0x98
arduino_atmega165.bootloader.extended_fuses=0xFF
arduino_atmega165.bootloader.path=atmega
arduino_atmega165.bootloader.file=bf_boot.hex
arduino_atmega165.bootloader.unlock_bits=0x3F
arduino_atmega165.bootloader.lock_bits=0x0F
arduino_atmega165.build.mcu=atmega165
arduino_atmega165.build.f_cpu=8000000L
arduino_atmega165.build.core=arduino
knut_ny
if there is no bootloader installed, you can use a programmer/an arduino to butn the bootloader (the nnn.hex-file)
the code you have shown, goes into the board.txt-file (add it to those already there)
Ny
