Topic: how to calculate resistor to a base of a 2n2222? (Read 11815 times) previous topic - next topic
cabecinhas
Hi, michael_x thank you for your answer!
I just did what you said and worked but the 2n222 started to get REALLY overheated.. I can't even touch it.
I was searching on internet in a while and found the Tip120 that I believe can handle easily 400mah. and is hfe 1000.
I made a simple design that I would like you to see if I'm understanding what you are telling me..
Could you take a look?
MarkT
Bear in mind darlingtons don't saturate, since the collector is held at about 0.8 to 1.5V
above the emitter due to the configuration.  So you'll probably get about 1/2 a watt of
heat from it.  At least it has a metal tab for a heatsink.
2N2222 isn't going to handle 400mA continuous comfortably without a lot of current into
the base, perhaps 60mA, to bring the Vsat down.  You could try driving it again with a
base resistor of 150 ohms, giving about 30mA base drive (the most that's safe for an
Arduino).  330 ohms is a bit too high.  It will still run hot, its a small package.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
cabecinhas
Hi, Mark. What If i change and use a bd135 instead?
MarkT
Look at its datasheet for the saturation characteristics?  Is it better or worse?
polymorph
Please try not to put your response inside the quotes. It makes it difficult or impossible to figure out what you are saying.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
cabecinhas
hi. I think its better because the it handles 1,5A and do the job easily.
And the gain is about 25-250. What exactly does this gain mean? I can count on 25 or 250?
michael_x
BD135 has a bigger case, but you should have a rather high IB, too.
In the datasheet you see saturation at IC = 10* IB,
In Fig 2. with a IC = 500mA and IB = 25mA (only) there's a VCE of typical 0.2V -->  0.1W heat
And there's the line VCE(sat)  @(IC = 500 mA, IB = 50 mA) with a max 0.5V ( 0.25W )
As for the TIP120, Rb = 9k is Max. I'd never calculate by hFE. ( Neither the 1000 here, nor the 25 ..250 for BD135 )
You don't want to use them as amplifiers but as switches.
( Rb = 1k @5V signal is more typical for a Darlington as switch )
Quote
How hot does your 5 Ohm resistor get, BTW ?
Res   400mA * 5 Ohm = 2 V -> 0.8W
Led    400mA * 3V = 1.2 W
________________
Total  400mA * 5V = 2 W
polymorph
If it says the gain is 25-250, what do you think? Would you count on gain being 250 if it can be anywhere between 25 and 250?
For saturation, overdrive the transistor.
