No. It just means they are inconsistent.
The voltage rating could be seen as "how many volts between the collector and emitter", in which case 45 volts is correct. Or "how many volts can be on the collector with reference to the emitter", in which case -45 volts is more correct.
Current is normally given a direction, not a polarity. However, many people and datasheets give it a negative value when it is running in the opposite to the "normal" direction. Since most transistors are NPN, the current in a PNP is traveling in the opposite direction to this "normal" direction.
That's all it really means.
