I am trying display and scroll texts with Parola for arduino sample codes + MAX 7219.
Those displays words, but they show reversed texts! Does anyone encountered to the same problem?
Here is the video link how it is look-a-like.
It will be great if you know some advice for it.
I tried to use scroll_right, but it doesn't work.
Tomomi
(code tags added by moderator)
// Program to demonstrate the MD_Parola library
// For every string defined by pc[] iterate through all combinations
// of entry and exit effects.
// Animation speed can be controlled using a pot on pin SPEED_IN
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define MAX_DEVICES 12
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// set to 1 if we are implementing the user interface pot
#define USE_UI_CONTROL 1
#if USE_UI_CONTROL
#define SPEED_IN A0
#endif // USE_UI_CONTROL
#define PAUSE_TIME 1000
#define SPEED_DEADBAND 5
uint8_t frameDelay = 25; // default frame delay value
#if INCLUDE_HARDWARE_SPI
MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
#else
MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
#endif // USE_HARDWARE_SPI
#define SPEED_TIME 25
// Turn on debug statements to the serial output
#define DEBUG 1
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
// Global variables
uint8_t curText;
char *pc[] =
"Parola for",
"Arduino",
uint8_t inFX, outFX;
MD_Parola::textEffect_t effect[] =
MD_Parola::PRINT,
MD_Parola::SCROLL_LEFT,
MD_Parola::WIPE,
MD_Parola::SCROLL_UP,
MD_Parola::OPENING_CURSOR,
MD_Parola::BLINDS,
MD_Parola::CLOSING,
MD_Parola::WIPE_CURSOR,
MD_Parola::DISSOLVE,
MD_Parola::OPENING,
MD_Parola::CLOSING_CURSOR,
MD_Parola::SCROLL_RIGHT,
MD_Parola::SCROLL_DOWN,
MD_Parola::SLICE,
#if USE_UI_CONTROL
void doUI(void)
// set the speed if it has changed
int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 0, 250);
// if ((speed >= ((int16_t)P.getSpeed() + SPEED_DEADBAND)) ||
// (speed <= ((int16_t)P.getSpeed() - SPEED_DEADBAND)))
if (speed != (int16_t)P.getSpeed())
P.setSpeed(speed);
P.setPause(speed);
frameDelay = speed;
PRINT("\nChanged speed to ", P.getSpeed());
void setup(void)
Serial.begin(57600);
PRINTS("[Parola Demo]");
#if USE_UI_CONTROL
pinMode(SPEED_IN, INPUT);
doUI();
P.begin();
P.setInvert(false);
P.displayText(pc[curText], MD_Parola::CENTER, SPEED_TIME, PAUSE_TIME, effect[inFX], effect[outFX]);
void loop(void)
#if USE_UI_CONTROL
doUI();
if (P.displayAnimate()) // animates and returns true when an animation is completed
// Set the display for the next string.
curText = (++curText) % ARRAY_SIZE(pc);
P.setTextBuffer(pc[curText]);
// When we have gone back to the first string, set a new exit effect
// and when we have done all those set a new entry effect.
if (curText == 0)
outFX = (++outFX) % ARRAY_SIZE(effect);
if (outFX == 0)
inFX = (++inFX) % ARRAY_SIZE(effect);
if (inFX == 0)
P.setInvert(!P.getInvert());
P.setTextEffect(effect[inFX], effect[outFX]);
// Tell Parola we have a new animation
P.displayReset();
