Topic: PWM Controling Various LED's (Read 912 times) previous topic - next topic
wizarcl
Jan 31, 2014, 01:51 am Last Edit: Jan 31, 2014, 01:56 am by wizarcl Reason: 1
This is my ciruit of my project:
        LED3_RED              56 Ohms
        |-------(<)------------/\/\/\/\------------      +5V
        |             LED2_RED              56 Ohms
        |             LED1_RED              56 Ohms
        10kOhms  |
Pin 9 (PWM) _|¯|_|¯|_|¯|_|¯|_   ----/\/\/\-----/             transistor BC549
        \>   Emiter
        GND
        LED3_GREEN              56 Ohms
        |             LED2_GREEN              56 Ohms
        |             LED1_GREEN              56 Ohms
        10kOhms  |
Pin 10 (PWM) _|¯|_|¯|_|¯|_|¯|_   ----/\/\/\-----/             transistor BC549
        \>   Emiter
        GND
        LED3_BLUE         56 Ohms
        |            LED2_BLUE         56 Ohms
        |             LED1_BLUE         56 Ohms
        10kOhms  |
Pin 11 (PWM) _|¯|_|¯|_|¯|_|¯|_   ----/\/\/\-----/             transistor BC549
        \>   Emiter
        GND
BC549 datasheet says... VCEsat (Coletor-Emiter Voltage in Saturation) is 0.2V with IC=100mA...
(5V - 0,2(VCEsat) - 3,3 (LED)) / 56Ohms =~ 27mA  per LED
It's working, but i wanna a second opnion about this circuit.
I have only one problem... When I write
Code: [Select]
turnOffPWM(TIMER1A)  //Pin9
turnOffPWM(TIMER1B) //Pin10
turnOffPWM(TIMER2A) //Pin11
to turn off Timers, but only working to TIMER2A (pin11). If I disconect transistor for RED, GREEN and BLUE turn off... Maybe same problem with polarization of transistors?
If I write:
Code: [Select]
analogWrite(9,0);
analogWrite(10,0);
analogWrite(11,0);
All colors is switched off...
PaulRB
Hi wizarcl,
Those 10K base resistors seem high to me. How did you work them out?
Why do you want to turn the pwm timers off, what is wrong with using analogWrite (x, 0)?
Paul
wizarcl
Hi wizarcl,
Sorry, I'm using 1K resistor and not 10K..
Quote
Paul
No problem with analogWrite(x,0), but, I would like to know why does not work. Theoretically it should.
I replace BC459 by TIP120 (more current limit, because, limit of BC is 200mA) and the problem with turnOffPWM isn't solved... I will try to measure Arduino PWM Outputs...
