Topic: Serial Monitor closes automatically when downloading. (Read 9166 times) previous topic - next topic
mechamania
Each time when I download a program, the Serial Monitor is closed. I Always use the Serial Monitor for output. I would like to have it open all the time so that the loading of a program and running it is faster. Can that be done?
spycatcher2k
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
JimboZA
Quote
Wow- how often are you uploading new code that it makes it so important?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
mechamania
Quote
I just like to have short debugging cycles and it is annoying.
But maybe the most important thing is that I miss the first output from the Arduino serial port (see other post).
JimboZA
I don't think you miss the first output, because my understanding is that when you open the monitor it resets the board so your sketch starts again anyway.
That might in itself be a problem of another sort though....
mechamania
I really would like to open the Serial Monitor without a Arduino reset. But I guess that is not supported.
JimboZA
mechamania
Read Reply#5 on this thread
If I understand corretly, this hack will also prevent a reset at upload. And that reset may be vital.
lostgdi
if you insisted, why not just put a delay after setup ?
As I know the arduino will also reset after your open operation. at less you have the chance to catch output of your expected.
mechamania
Yes I guess that is best.
cmiyc
An alternative to a delay is this:
Code: [Select]
  Serial.println(F("Waiting for 1 character"));
  while(Serial.read() == -1);
Set the return dropdown to "No line ending."   The program will wait until you send a single character before moving on.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
westfw
I think is a frequently-requested feature that the serial monitor be RE-opened after an upload, which would probably make the original poster happy.  Since the serial monitor and avrdude (used for uploading) are actually separate programs, they can't both have the serial port open at the same time.
