Topic: Arduino Mega 2560 Serial port troubles[solved] (Read 1 time) previous topic - next topic
JifVince
Feb 05, 2014, 05:22 pm Last Edit: Feb 05, 2014, 06:29 pm by JifVince Reason: 1
Hi everyone,
I get some troubles to communicate via the 3 extra serial ports of my Arduino Mega board.
I made a program to transcript GPS trames to AIS trames to be read by a Navigation software, until now it worked fine, and since I upgrade Windows 8.1, I can't communicate with the Serial ports but the USB serial.
The Serial USB port is working fine (blinking Tx led for a test pg), but when I use either Serial1, Serial2, and Serial3 for the same program, I can't get the signal that should appear. Even the Tx led is not blinking.
Here is the program that im using to test the serial ports.
void setup(){
//  Serial.begin(4800);
 Serial1.begin(4800);
void loop(){
//  Serial.print("test");
 Serial1.print("test");
I am using Windows 8.1 64 bits. I may have forget some informations, it is the first time I post on the forum  :).
If anyone gets an idea about where this is comming from, I don't know what to do anymore
Thanks
spycatcher2k
How are you trying to read the ports? you will get nothing from the USB as it is only connected to Serial.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
JifVince
Hi, thanks for answering.
I read the serial from a serial reader software,Termite, via a Max232 ship. It works fine during the past 2 mounth.
Do you think it may be due to a wrong driver installation? The Tx and Rx leds should be blinking anyway if I send something from the serial1 2 or 3 right ?
Thanks
spycatcher2k
On the MAX232 board - yes - on the mega - No, the Rx/Tx leds are run from the FTDI/16u4 chip
Mrs Drew
JifVince
Ok, thank you, I finally found a default in my DB9 plug :*
A shame that you lost some time for my problem sorry!!
Thanks for the infos anyway. It was a good reason for me to suscribe to the forum :).
Vincent
spycatcher2k
Mrs Drew
