Topic: dash board speedo, arduino uno (Read 729 times) previous topic - next topic
canemichael97
Feb 07, 2014, 06:58 pm Last Edit: Feb 07, 2014, 07:47 pm by canemichael97 Reason: 1
HI, i am using the dashboard out of a jcb loader (pic attatched) for a project i am doing, i want to use the speedo on the display. the data sheet tells me there is a pin for 12v, ground and a signal rail for the speedo.  the data sheet tells me that the gauge runs of Hz through the signal rail.  i was going to collect the speed by using a magnetic reed switch attached to the wheel and axel.  how would i then output this data to the gauge?
pylon
Have you tried just supplying the signal that comes from the reed contact?
