Topic: Sequence leds and button to activate a counter. (Read 1 time) previous topic - next topic
dotgridline
Hi ther, I have 5 leds connected to a protoboard and also, one button. I tested this code several times, each time with a function alone. Alone, they all work. But when I try to mix them, it doesn't work. What I need is: I need the 5 leds to light on and off in sequence, and then I need the user to push the button when only the red one, the third, is on. If he do it, I just need to add a ++ to the counter.
Can someone help me, please?
All the connections are right and all the positions in the arduino too.
Code: [Select]
const int buttonOrange = 2;
const int ledOne  = 13;
const int ledTwo  = 12;
const int ledRed  = 11;
const int ledFour = 10;
const int ledFive = 9;
// Array of Pins
int ledPins[] = {            // an array of variables refering pin numbers to which LEDs are attached
  ledOne,
  ledTwo,
  ledRed,
  ledFour,
  ledFive
int delayTime = 400;
int clickCounter = 0;
int buttonState = 0;
int ledState = 0;
int lastButtonState = 0;
  for (int currentPin = 0; currentPin <= 5; currentPin++)  {
    pinMode(ledPins[currentPin], OUTPUT);
  pinMode(buttonOrange, INPUT);
void loop(){
  buttonState = digitalRead(buttonOrange);
  ledState = digitalRead(ledRed);
  for(int i = 0; i <= 5; i++){
    int offLED = i - 1;
      if(i == 0) {
        offLED = 5;
      if (buttonState != lastButtonState) {
        if(buttonState == HIGH && ledRed == HIGH){
          clickCounter++;
          Serial.println(clickCounter);
    lastButtonState = buttonState;
    digitalWrite(ledPins[i], HIGH);
    digitalWrite(ledPins[offLED], LOW);
    delay(delayTime);
AiRgeek
It would be easier for others to read and understand your code, if you comment your code more to explain the control flow and purpose of variables.
