Topic: [SOLVED] Deek/Dswy Robot Mini Pro - can't upload a sketch & bootloader (Read 51005 times) previous topic - next topic
grmis
Same problem for me, with exaclty the same board and same symptoms.  I got this Arduino pro mini on eBay and this si what the (eBay) seller has just replied to me:
Quote
In fact, we have found the problem in this version board, in the bottom, it mark " DSWY-ROBET"
the bootloader in the mini board have some problem. Here are the instructions for somebody else having trouble:
Using USBasp programmer, first the IC should be re-set before burning the bootloader and this id done by the following command:
"avrdude -p m328p -c USBasp -P USB -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m -B4"
This will erase the IC and then can be programmed using just the arduino IDE.  We have stop to sell this version.
We get another version like your first shopping, it mark "DEEK-ROBET", it will never happen such thing again
Regards
mrlowalowa
Joining the list with this awful clone..
Burned the Bootloader via my Arduino Uno with the exact same wiring as shown here! Thanks for that! :)
A friend of me has already the second new product line, without the label Deek-Bot and labeling of the pins again at the right site...
Cheers! :)
yesyes
thanks so much for posting the solution!! A life saver!
I bought 5 of these Arduinos, already installed some of them in my project and then wasn't able to upload any sketches. The Nano as ISP method worked perfectly! ;) All 5 Minis saved!
Chris
Chris
My Astro and DIY projects website: http://yesyes.info/
yenan1001
#18
Apr 14, 2014, 05:12 pm Last Edit: Apr 14, 2014, 05:22 pm by yenan1001 Reason: 1
Hi there,
below is my output when I use my UNO as ISP to burn the bootloader.
the error is
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
and now, the dswy robot does not blink, seems die.
I have no idea how to solve. any advice?
Code: [Select]
Arduino:nightly (Windows 8), ??"Arduino Uno"
C:\Users\yenan_000\Desktop\arduino-nightly/hardware/tools/avr/bin/avrdude -CC:\Users\yenan_000\Desktop\arduino-nightly/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "C:\Users\yenan_000\Desktop\arduino-nightly/hardware/tools/avr/etc/avrdude.conf"
        Using Port                    : COM4
        Using Programmer              : stk500v1
        Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
        AVR Part                      : ATMEGA328P
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : STK500
        Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
        Hardware Version: 2
        Firmware Version: 1.18
        Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
        Vtarget         : 0.0 V
        Varef           : 0.0 V
        Oscillator      : Off
        SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.06s
        this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
yenan1001
May I know how to use this command.
really need a brief instruction.
thank you.
Quote
Regards
mrlowalowa
Are you Using the newst Arudion IDE Version and are the ConnectionID right to the clone?
They are Different than in the Sketch! Look at the Thread roundtable about post 7-10 i'm in mobile..
For avrdude, You need to install avrdude on your pc. For me it didn't worked that was but have a try! :)
Greets from germany
yenan1001
Greets from germany
Thanks, I'm useing 1.5.6 version IDE, I will try the 1.05.
Besmrtnik
pls help me, I have same "mini pro"
same issue, I tryed everything you told me but it doest not work for me
I always get this messidge
  this messidge I give power to mini from uno programmer
         this check.
 this messigge I get when I give him external power 5V
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
1. Download the ISP-sketch to your programmer arduino (a nano in my case)          +check
2.  Follow the instructions in the sketch description to wire the status leds             +check
3. Connect Nano and Mini (Nano->Mini, D13->D13, D12->D12, D11->D11, D10->Reset)      +check
4. Connect Vcc and Gnd from the USB2Serial adapter (cp12xx in my case, or any other puwer suply) to the mini       +check
5. In the IDE,  choose the com port, select Board->Mini or Mini Pro, Programmer->Arduino as ISP    +check
6. IDE->Burn Bootloader  +check
7. wait for about 2 minutes...    -- after 10 seconds error
8. be happy     ---------------Its not working...
I am sure its dswy robot mini pro, 5v at328
I also bought few of them, and  I want get them to work, I have done 10 times all you said and with variations and I cant get it to work
how do I use -F
yenan1001
I tried again with IDE 1.0.5r2.
connect the UNO VCC and GND to pro mini.
reload IPS to UNO.
select COM4
select board pro mini.
burn bootloader.
below is what I get. don't know what to do next.
pls help.
Code: [Select]
C:\Users\yenan_000\Desktop\arduino-1.0.5-r2-windows\arduino-1.0.5-r2\hardware/tools/avr/bin/avrdude -CC:\Users\yenan_000\Desktop\arduino-1.0.5-r2-windows\arduino-1.0.5-r2\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
         System wide configuration file is "C:\Users\yenan_000\Desktop\arduino-1.0.5-r2-windows\arduino-1.0.5-r2\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM4
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Recv:
         this check.
avrdude: Recv:
Besmrtnik
#24
Apr 24, 2014, 03:37 pm Last Edit: Apr 24, 2014, 03:41 pm by Besmrtnik Reason: 1
I finally fixed it, I am so happy right now :D
I solder up all connections so I am 100% sure that maybe something isn't connected
this time I followed solution from sparkfun forum
https://forum.sparkfun.com/viewtopic.php?f=32&t=27960
1. Connect the Arduino Uno via USB to the PC
2. Open the Arduino IDE
3. Arduino IDE > Tools > Serial Port >  (Select port of your Arduino UNO)
4. Arduino IDE > File > Examples > ArduinoISP
5. Upload the sketch. once complete your Arduino Uno is now programmed to be an ISP programmer.
6. Power the Uno off and wire the Uno to the Arduino Pro Mini in the following fashion:
Uno---------------Pro Mini
5V(VCC)-----------------------VCC
GND------------------------GND
Digital Pin 11(MOSI)----pin 11 (MOSI)
Digital Pin 12(MISO)----pin 12 (MISO)
Digital Pin 13(SCK)-----pin 13 (SCK)
Digital Pin 10----------RST
7. Power on the Uno
8.  Arduino IDE > Tools > Board > Arduino Pro or Pro Mini (5V, 16MHz) w/ ATmega328
9.  Arduino IDE > Tools > Programmer > Arduino as ISP      (this option I had checked even in step 5 while uploading IPS sketch, because of previous attempts)
10. Arduino IDE > Tools > Burn Bootloader
also I want to give some more info, on lots of examples on internet and youtube, I saw lots of ppl removing their ATmega chip from their arduino uno to program pro mini... That looked kind a silly to me, and I manage to found solution.
http://proto-pic.com/Datasheets/pro-mini/UNO_PROMINI.pdf
Step 1.
Connect jumpers as follows
Arduino UNO              -->        pro mini
RESET   --   GND
                       RX        -->         RXD
                        TX       -->         TXD
                     VCC        -->        VCC
                    GND        -->        GND
and yes RX goes to RX and TX to TX for sure :)
Step 2.
Plug the arduino into the USB lead as normal
Step 3.
Step 4.
Load/Type your sketch into the IDE
Step 5.
Click the Upload Icon or Arduino IDE > File > Upload
Step 6.
When the sketch size show in the debug panel (The bottom of the IDE)
Tap the reset button on the Pro Mini - This starts the bootloader.
if you get error "avrdude: stk500_getsync(): not in sync: resp=0x00"
practice your timing with clicking reset button after seeing "Binary sketch size: 3.772 bytes (of a 30.720 byte maximum)"
If there are any error messages - Double check the wiring, The most common cause of error is
connecting the Rx and Tx lines back to front.
I hope it will help someone,
anyway those little pro minis are fantastic :D
ichilton
I have a few Deek-Robot Arduino Mini's, which work fine. They originally came with the Duemilanove bootloader, but I upgraded that to the Uno one.
I then ordered 5x more, from a different seller, and what came was some of the Dswy Robot pictured in the first post in this thread - with the labelling on the bottom and extra ISP pins.
However, like the other posts in this thread, whichever board I choose from the Arduino IDE, I can not get it to upload.
I had already tried a number of times to flash a new bootloader using my USBtinyISP (which works fine with other boards, including the Deek-Robot Arduino Mini's), but I was unable to make it work on these.
I've just come across this thread, so tried using an Arduino Uno as an ArduinoISP, but that doesn't work either. I've also tried a USBasp.
I've tried using the ISP pins with a little pogo pin type adapter, or wiring direct to pins 11, 12, 13, RESET & GND. I've tried powering the board from the programmer / uno and tried powering it separately with my serial adapter.
I've tried the avrdude command posted above.
All I get with all of these methods - and all 5x boards, is "Invalid Device Signature".
What's interesting though is that when I first powered them on, I did get the green light slowly flashing like other describe. However, after trying the above, none of them give that any more....
I've tried checking with a multimeter that the relevant connections on the board (Vcc, Gnd, Reset, SPI pins, serial pins) correctly connect back to the right pins on the ATMega328P-AU, and they do.
Any ideas?
Thanks,
Ian
ichilton
#26
Apr 24, 2014, 08:58 pm Last Edit: Apr 24, 2014, 10:47 pm by Ian Chilton Reason: 1
Code: [Select]
Further to my post above, here is the exact output:
[code]
>avrdude -p m328p -c USBtiny -P USB -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m -B4
        this check.
and with -F:
Code: [Select]
>avrdude -p m328p -c USBtiny -P USB -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m -B4 -F
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
From the Arduino IDE, doing Burn Bootloader, I get:
Code: [Select]
        this check.
Putting the same wires into the same pins on one of my working Derk-Robot ones, I get:
Code: [Select]
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0x05"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0x05:
avrdude: load data efuse data from input file 0x05:
avrdude: input file 0x05 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDA"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDA:
avrdude: load data hfuse data from input file 0xDA:
avrdude: input file 0xDA contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.00s
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: safemode: Fuses OK
And then when I do burn bootloader in the Arduino IDE, it completes successfully - so my programmer & cables are working fine.
I guess it's looking like these Dswy_Robot boards are faulty, but it's just odd that all 5x are the same, and that it was obviously running a sketch from the factory as I was getting the very slow flashing green LED on them all before I started trying to burn the bootloader.
Anything else I can do/try?
Thanks,
Ian
[/code]
yenan1001
I tried to burn the bootloader again. same error message.
one more thing I noted is that, the LED on my pro mini never blink.
not sure it is good news or bad.
3.3v-----------------------VCC
Code: [Select]
Arduino:nightly (Windows 8), ??"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
C:\Users\yenan_000\Desktop\arduino-nightly/hardware/tools/avr/bin/avrdude -CC:\Users\yenan_000\Desktop\arduino-nightly/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
         Using Port                    : COM4
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Recv: . [ff]
avrdude: Device signature = 0xffffff
         this check.
Andrew8098
I just wanted to first thank everyone for the info on this topic. it saved my project too.
the second point I wanted to make, im not sure if it was me misreading (i am sick with the flu) or if some of the posts were incorrect.  but I just want to clarify that when you are loading the bootloader by using your Uno, etc. as ISP that you need to connect your UNOs pin 10 to the Mini's reset pin, not the other way around.  I was getting an error the same as a number of people were stating so i think i might not be the only one who made that error.
again, thank you. I can wait to put this mini to use in an existing project so I can free up my Uno for new projects.
jpiffr
I got two of these DSWY ROBOT boards and I have a problem that was previously mentioned. However, I lost track of who answered what, so I need some help.
These are the first boards I got along with a Mega 2560. I programmed the Mega as an ISP using the example code. When it is connected to the computer LED 9 pulses (I think that is supposed to be the "heartbeat" so it is working. I connected my mini as follows.
Mega------->Mini
53----------->reset
52----------->13
51------------>11
50----------->12
I also tried connecting the corresponding ICSP pins to no avail. The error is "Yikes! Invalid device signature." The Mini started with the slow blink, but after I tried to bootload, the LED does not light up.
Any help would be greatly appreciated. Thank you in advance.
