Topic: Take a picture whit Arduino Yun (Read 3849 times) previous topic - next topic
Zack91
Hello, i'm trying to take a picture with my Arduino Yun and web cam.
For this I have followed this guide:
http://www.lucadentella.it/en/2013/11/15/yun-colleghiamo-una-webcam-1/
But when i'm going to take a picture, i have this response:
Code: [Select]
root@Arduino:~# cd ..
root@Arduino:/# cd mnt/sda1/
root@Arduino:/mnt/sda1# fswebcam --save p1.jpg
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
No input was specified, using the first.
Adjusting resolution from 384x288 to 352x288.
Error starting stream.
VIDIOC_STREAMON: No space left on device
Unable to use mmap. Using read instead.
Unable to use read.
When i connect my webcam device, i think it is recognized, here the system log:
Feb 14 13:19:35 Arduino kern.info kernel: [  512.560000] usb 1-1.1: USB disconnect, device number 3
Feb 14 13:19:38 Arduino kern.info kernel: [  515.360000] usb 1-1.1: new full-speed USB device number 5 using ehci-platform
Feb 14 13:19:38 Arduino kern.info kernel: [  515.490000] usb 1-1.1: not running at top speed; connect to a high speed hub
Feb 14 13:19:38 Arduino kern.info kernel: [  515.490000] usb 1-1.1: New USB device found, idVendor=18ec, idProduct=3290
Feb 14 13:19:38 Arduino kern.info kernel: [  515.490000] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 14 13:19:38 Arduino kern.info kernel: [  515.500000] usb 1-1.1: Product: USB2.0 PC CAMERA
Feb 14 13:19:38 Arduino kern.info kernel: [  515.500000] usb 1-1.1: Manufacturer: ARKMICRO
Feb 14 13:19:38 Arduino kern.info kernel: [  515.500000] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (18ec:3290)
Feb 14 13:19:38 Arduino kern.info kernel: [  515.510000] input: USB2.0 PC CAMERA as /devices/platform/ehci-platform/usb1/1-1/1-1.1/1-1.1:1.0/input/input2
Feb 14 13:21:43 Arduino kern.info kernel: [  640.050000] usb 1-1.1: USB disconnect, device number 5
Feb 14 13:21:56 Arduino kern.info kernel: [  653.090000] usb 1-1.1: new full-speed USB device number 6 using ehci-platform
Feb 14 13:21:56 Arduino kern.info kernel: [  653.220000] usb 1-1.1: not running at top speed; connect to a high speed hub
Feb 14 13:21:56 Arduino kern.info kernel: [  653.220000] usb 1-1.1: New USB device found, idVendor=18ec, idProduct=3290
Feb 14 13:21:56 Arduino kern.info kernel: [  653.220000] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 14 13:21:56 Arduino kern.info kernel: [  653.230000] usb 1-1.1: Product: USB2.0 PC CAMERA
Feb 14 13:21:56 Arduino kern.info kernel: [  653.230000] usb 1-1.1: Manufacturer: ARKMICRO
Feb 14 13:21:56 Arduino kern.info kernel: [  653.230000] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (18ec:3290)
Feb 14 13:21:56 Arduino kern.info kernel: [  653.240000] input: USB2.0 PC CAMERA as /devices/platform/ehci-platform/usb1/1-1/1-1.1/1-1.1:1.0/input/input3
Why ? What is the problem ?
Thanks for your attention.
lucad79
Hi Zack
that error normally means you have some issues with a device connected to your USB port: I got the same when I tried to use two webcams at the same time. What did you connect to the Yun? Only a webcam? Which is its manufacturer/model?
www.lucadentella.it
Zack91
I have connected one webcam (USB2.0 PC CAMERA by ARKMICRO) by usb port and sd.
The notebook has a camera but it should not detect it.
lucad79
run the
Code: [Select]
lsusb command and post the output... it seems from the dmesg you posted that the webcam is detected more than one time  :smiley-eek-blue:
www.lucadentella.it
Zack91
root@Arduino:~# lsusb
Bus 001 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 18ec:3290 Arkmicro Technologies Inc.                              <=Camera
Bus 001 Device 003: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
lucad79
well referring to this webpage:
http://www.ideasonboard.org/uvc/
your webcam should be supported by UVC: have you already installed all the required packages in Yun?
www.lucadentella.it
Zack91
#6
Feb 17, 2014, 10:14 am Last Edit: Feb 17, 2014, 10:52 am by Zack91 Reason: 1
Yes, the camera is supported and I installed the packages as indicated by the guide that i link in the first post.
On the internet I found information about the problem, it says that I have more than a webcam, but it is not.
Also I have found information that talks about the BW usb port, that the camera is not enough.
ideas ?
Thanks.
edit:
The porcess for steps:
Code: [Select]
root@Arduino:/mnt/sda1# fswebcam -v --save 1.jpg
main,1609: gd has no fontconfig support
/dev/video0 opened.
src_v4l2_get_capability,87: /dev/video0 information:
src_v4l2_get_capability,88: cap.driver: "uvcvideo"
src_v4l2_get_capability,89: cap.card: "USB2.0 PC CAMERA"
src_v4l2_get_capability,90: cap.bus_info: "usb-ehci-platform-1.1"
src_v4l2_get_capability,91: cap.capabilities=0x84000001
src_v4l2_get_capability,92: - VIDEO_CAPTURE
src_v4l2_get_capability,103: - STREAMING
src_v4l2_set_input,181: /dev/video0: Input 0 information:
src_v4l2_set_input,182: name = "Camera 1"
src_v4l2_set_input,183: type = 00000002
src_v4l2_set_input,185: - CAMERA
src_v4l2_set_input,186: audioset = 00000000
src_v4l2_set_input,187: tuner = 00000000
src_v4l2_set_input,188: status = 00000000
src_v4l2_set_pix_format,541: Device offers the following V4L2 pixel formats:
src_v4l2_set_pix_format,554: 0: [0x47504A4D] 'MJPG' (MJPEG)
Using palette MJPEG
src_v4l2_set_mmap,693: mmap information:
src_v4l2_set_mmap,694: frames=4
src_v4l2_set_mmap,741: 0 length=202752
src_v4l2_set_mmap,741: 1 length=202752
src_v4l2_set_mmap,741: 2 length=202752
src_v4l2_set_mmap,741: 3 length=202752
Unable to use read.
Yuntastic
It's probably because the yun usb can't provide sufficient power (I had the same problem and symptoms).
TRy using a powered hub - this one works great for me: http://www.amazon.co.uk/D-Link-DUB-H7-Port-USB-External/dp/B0002AFZVM
