Topic: New TFT Extension Library (Read 64476 times) previous topic - next topic
ikravets
Thanks a lot for your job!
Can you share this library on https://github.com, then I will add it to PlatformIO Library Register.
HazardsMind
I am in the process of setting up a Github account but I dont know how to use Github.
ikravets
HazardsMind
ikravets
#79
Oct 08, 2014, 10:19 am Last Edit: Oct 08, 2014, 03:24 pm by ikravets Reason: 1
Looks great for beginning! But CVS(like, SVN, GIT) was developed for keep track of all work and all changes in a set of files. This isn't good practice to keep in repository source that was packed in archive.
I recommend to create for each library separated repository with detailed information about it inside README.md file. See TOP examples by "arduino library" search query on GitHub:
and etc.
In your case the list of repositories:
  • Arduino-OneWireKeypad
  • Arduino-SeeedTouchScreen_V2
  • Arduino-SerialServo
and etc..
P.S: Which OS type do you use?
HazardsMind
This is the first time I have ever used Github and it is not straight forward or easy at all, so I'm surprised I was able to post anything.
Quote
I will look into that.
I am using Windows 8.1
robsworld78
Hi, nice library you've created, thanks for sharing. I'm interested in using the vertical slider but I'm using a 5" display and having troubles. When I load the example it shows 3 bars on the display with a box. The touch isn't working on the actual sliders, to move them I need to touch other areas of the screen and instead of sliding vertically I have to slide horizontally? The square box does show the color mix like it should.
I opened the .cpp file and saw the display resolution, I changed it to 800x480 but that doesn't seem to affect it any.
Do you have any idea?
HazardsMind
#82
Oct 24, 2014, 09:09 pm Last Edit: Oct 27, 2014, 05:43 pm by HazardsMind
Do you know if your touchscreen calibrated correctly? What screen orientation are you using and is it the same for the UTFT, UTouch and my library's setting?
Try this code and see if the values make sense. (Be sure to change the constructors)
Code: [Select]
#include <UTFT.h>
#include <UTouch.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
//myGLCD(RS,WR,CS,RST,ALE,mode);
UTFT myGLCD(ITDB32S,A1,A2,A0,A3,A5);
//myTouch(TCLK,TCS,DIN,DOUT,IRQ);
UTouch  myTouch(13,10,11,12,A4);
  myGLCD.InitLCD(LANDSCAPE);
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch(LANDSCAPE);
  myTouch.setPrecision(PREC_LOW);
  myGLCD.fillScr(0,0,0);
  myTouch.read();
  Debug(myTouch.getX(), myTouch.getY());
void Debug(int X, int Y)
  myGLCD.setBackColor(0, 0, 0);//background of text is black
  myGLCD.setColor(255,255,255); // test color is white
  myGLCD.print("X: ", 0,0, 0);
  if(X < 100){
    myGLCD.print("  ", 29,0, 0);
    myGLCD.printNumI(X, 24, 0);
  else myGLCD.printNumI(X, 24, 0);
  myGLCD.print("Y: ", 55,0,0);
  if(Y < 100){
    myGLCD.print("  ", 84,0, 0);
    myGLCD.printNumI(Y, 79, 0);
  else myGLCD.printNumI(Y, 79, 0);
HazardsMind
UPDATE Version 1.3
Fixed keyboard color, added a few new functions for the Latch(Button/Circle/Triangle)_Draw functions. Now you can set/reset the state of the latch buttons to a specific state -> PRESSED or RELEASED. (Suggestion from No1Daemon)
ResetLatchButtonState
ResetAllLatchButtonState
ResetLatchCircleState
ResetAllLatchCircleState
ResetLatchTriangleState
ResetAllLatchTriangleState
See Latching Buttons example sketch.
Updated Constructor to just TFT_Extension myTFT(&myGLCD, &myTouch);, No need for landscape or portrait.
Added new Initializer function, myTFT.ExtSetup(); This will take care of the display size and orientation.
Fixed color pallet from RGB to 565 format.
As always, if you have an idea you want to add, let me know and I will be happy to add it. :)
FlightFixit
  Hello, I am building a home automation system with a 4,3" TFT LCD screen and i am having a wonderful time coding the visuals of the system with your library, but i have a few questions.
  The main one is how i would go about making a custom shaped button, as for what i am designing i really need to figure out how to do this.
  What i want to do is make a square button, accept the lower left hand corner of the button is cut off and there is a diagonal line instead. I really need the diagonal to start about 30 pixels back on both lines, then connect the two together.
The total button size is 145px long and 75px tall. Thanks, Isaac N.
HazardsMind
You could just draw the shape and use TouchButton, not TouchButton_Draw.
TouchButton will work like TouchButton_Draw, but you wont see the button change colors when pressed.
FlightFixit
The main issue that i am having is that i can not figure out how to draw the general shape, never the less make it into a button.
HazardsMind
#87
Dec 30, 2014, 04:25 pm Last Edit: Mar 10, 2015, 01:39 am by HazardsMind
You would need to make your own functions to do custom shapes.
Something like this. (Untested)
Code: [Select]
void customShape(int x, int y, int w, int h, int Cx1, int Cy1, int Cx2, int Cy2, word Color)
  float slope = (Cx2 - Cx1) / (Cy2 - Cy1);
  for (int Dy = y; Dy < y + h; Dy++)
    myGLCD.setColor(Color);
    if (Dy < Cy1)
      myGLCD.drawLine(x, Dy, x + w, Dy);
      myGLCD.drawLine(x + slope * Dy, Dy, x + w, Dy);
HazardsMind
Update to password sketch.
Password can be any length within the range of an unsigned long variable and pressing * or # will test the password as either PASS or FAIL.
Code: [Select]
#include <UTFT.h>
#include <UTouch.h>
#include <TFT_Extension.h>
extern uint8_t BigFont[];
UTFT myGLCD(ITDB32S, A1, A2, A0, A3, A5);
UTouch  myTouch(13, 10, 11, 12, A4);
//For using the older ITDB02 libraries
//#include <ITDB02_Graph16.h>
//#include <ITDB02_Touch.h>
//#include <TFT_Extension_old.h>
//// Declare which fonts we will be using
//extern uint8_t SmallFont[];
//extern uint8_t BigFont[];
////myGLCD(RS,WR,CS,RST,ALE,mode);
//ITDB02 myGLCD(A1,A2,A0,A3,A5,ITDB32S);
////myTouch(TCLK,TCS,DIN,DOUT,IRQ);
//ITDB02_Touch  myTouch(13,10,11,12,A4);
//TFT_Extension_old myTFT(&myGLCD, &myTouch);
char * PassText[4][3] = {
  {"1", "2", "3"},
  {"4", "5", "6"},
  {"7", "8", "9"},
  {"*", "0", "#"}
unsigned long MasterPassword = 2651; // can be any length within the range of an unsigned long variable
  myTouch.setPrecision(PREC_EXTREME);
  myTFT.ExtSetup();
  for (int line = 0; line <= 239; line++) // custom background color
    myGLCD.setColor(0, 0, line);//text color White
    myGLCD.drawLine(0, line, 319, line);
  PassWord_makeButton();
  PassWord_buttonText();
  GetPassword();
void PassWord_makeButton()
  for (int y = 0; y < 300; y += 100)
    for (int x = 0; x < 200; x += 50)
      drawButton(20 + x, 90 + y, 50 + x, 30 + y); // this will draw the button on the screen by so many pixels
  return;
void drawButton(int x1, int y1, int x2, int y2)
  myGLCD.setColor(170, 170, 170); // grey
  myGLCD.fillRoundRect(y1 - 3, x1 + 3, y2 - 3, x2 + 3); //Button Shading
  myGLCD.setColor(255, 255, 255); // white
  myGLCD.fillRoundRect(y1, x1, y2, x2);// outter button color
  myGLCD.setColor(200, 0, 0); // red
  myGLCD.fillRoundRect(y1 - 5, x1 + 5, y2 + 5, x2 - 5); //inner button color
  return;
void PassWord_buttonText()
  myGLCD.setFont(BigFont);
  myGLCD.setBackColor(200, 0, 0);
  for (int tr = 0; tr < 300; tr += 100)
    for (int tc = 0; tc < 200; tc += 50)
      char *myText = PassText[tc / 50][tr / 100];
      myGLCD.print(myText, 52 + tr, 27 + tc, 0); //this will print the number into the center of the buttons
void GetPassword()
  bool PassFound = false, P_lock[12] = {false};
  unsigned long password = 0;
  byte i = 0;
  while (PassFound == false)
        if ( i < 12)
          if (myTFT.TouchButton((90 + tr), (20 + tc), (30 + tr), (50 + tc)) && P_lock[i] == false) // this check to see if any of the buttons were pressed, then it sends the corresponding number to the "check" function
            if (strcmp(PassText[tc / 50][tr / 100], "*") && strcmp(PassText[tc / 50][tr / 100], "#")) // pressing * or # will test the entered password
              password = (password * 10) + ((PassText[tc / 50][tr / 100])[0]) - '0';
              myGLCD.printNumI(password, CENTER, 1); // show the password as it is being entered
              P_lock[i] = true;
              PassFound = checkPassword(2651);
              password = 0;
              myGLCD.print("    ", CENTER, 1);
            P_lock[i] = false;
          i++;
          i = 0;
bool checkPassword(unsigned long P)
  bool PF = false;
  if (P == MasterPassword)
    myGLCD.print("GOOD", CENTER, 1);
    PF = true;
    myGLCD.print("FAIL", CENTER, 1);
  return PF;
BTW, I am still working on the new library, TFTExtensionV2.
HazardsMind
Simple Calculator:
Code: [Select]
#include <UTFT.h>
#include <UTouch.h>
//ITDB02 myGLCD(A1, A2, A0, A3, A5, ITDB32S);
//ITDB02_Touch  myTouch(13, 10, 11, 12, A4);
const byte ROWS = 4;
const byte COLS = 4;
char * keys[ROWS][COLS] = {
  {"1", "2", "3", "+"},
  {"4", "5", "6", "-"},
  {"7", "8", "9", "x"},
  {"C", "0", "=", "/"}
byte i = 0, N = 0;
char Type = 0;
bool lock = false, P = false;
long num[2] = {0};
float total = 0;
char Op = ' ';
char Values[20];
  myTFT.ExtSetup();
  Calculator_makeButton();
  Calculator_buttonText();
  Calculator();
void Calculator_makeButton()
  for (int x = 0; x < 300; x += 75)
    for (int y = 0; y < 200; y += 50)
      drawButton(75 + x, 40 + y, 15 + x, 70 + y); // this will draw the button on the screen by so many pixels
  return;
  myGLCD.fillRoundRect(x1 - 3, y1 + 3, x2 - 3, y2 + 3); //Button Shading
  myGLCD.fillRoundRect(x1, y1, x2, y2);// outter button color
  myGLCD.fillRoundRect(x1 - 5, y1 + 5, x2 + 5, y2 - 5); //inner button color
  return;
void Calculator_buttonText()
  for (int tr = 0; tr < 300; tr += 75)
      char *myText = keys[tc / 50][tr / 75];
      myGLCD.print(myText, 36 + tr, 47 + tc, 0); //this will print the number into the center of the buttons
void Calculator()
  myGLCD.setBackColor(BLACK);
      if (myTFT.TouchButton((75 + tr), (40 + tc), (15 + tr), (70 + tc)) && !strcmp((keys[tc / 50][tr / 75]), "=") ) // Check for equal sign is pressed
        switch (Type)
          case 0: total = num[0] + num[1]; break;
          case 1: total = num[0] - num[1]; break;
          case 2: total = num[0] * num[1]; break;
          case 3: total = num[0] / num[1]; break;
        Type = -1;
        //Tft.fillRectangle(0, 30, 50, 20, BLACK);
        myGLCD.setColor(WHITE);
        myGLCD.printNumI(total, CENTER, 18);
        num[0] = 0;
        num[1] = 0;
        total = 0;
        N = 0;
        Op = ' ';
      if (myTFT.TouchButton((75 + tr), (40 + tc), (15 + tr), (70 + tc)) && !lock && ((tr / 75) != 3)) // make sure no operator is stored as a number
        myGLCD.setColor(BLACK);
        //myGLCD.fillRect(0, 0, 239, 20);
        if (strcmp(keys[tc / 50][tr / 75], "C") && strcmp(keys[tc / 50][tr / 75], "=") ) // get numbers while they are not the equal sign
          num[N] = (num[N] * 10) + ((keys[tc / 50][tr / 75])[0]) - '0';
          //myGLCD.printNumI(num[N],0, 1);
          lock = true;
      if (myTFT.TouchButton((75 + tr), (40 + tc), (15 + tr), (70 + tc)) && ((tr / 75) == 3) )//check for an operator
        Type = (tc / 50);
        switch (Type)
          case 0: Op = '+'; break;
          case 1: Op = '-'; break;
          case 2: Op = '*'; break;
          case 3: Op = '/'; break;
        //C_buttons[i].setForeColor(RED);
        N = 1;
        lock = false;
      if (myTFT.TouchButton((75 + tr), (40 + tc), (15 + tr), (70 + tc)) && !strcmp(keys[tc / 50][tr / 75], "C"))//clear the screen
        for (int line = 0; line <= 35; line++) // custom background color
      sprintf(Values, "%ld %c %ld", num[0], Op, num[1]);
      myGLCD.print(Values, 0, 1);
