Topic: Two wire multi color led - How to control (Read 4816 times) previous topic - next topic
dre3rd
Newbie, of course -- Old, 66 two days ago --  Trying to learn, is there anything else to do at this age?
Does anyone know where I can go to get info on controlling a 2 wire multi color led, the type found in cheap solar powered lawn ornaments such as the ones sold at Harbor Freight.
Thanks in advance
Dan  :~
CrossRoads
Connect it to two output pins, with a current limit resistor, like 270 ohm.
A  High, B Low, light one color
A Low, B High, light the other color
A & B both High or both Low, no color lit up
dre3rd
Thank you for the reply.  However it is multicolor, about 5 or 6 different with one fading to the other.  Sorry I wasn't clearer at first.
Quote
CrossRoads
Drive it with PWM signal and inverted PWM signal.
Use 74AC04 as inverter
http://www.digikey.com/product-detail/en/SN74AC04N/296-4290-5-ND/375817
CrossRoads
Course, if you want to turn both off, will need a way to 'gate' the PWM output to achieve one of the off states.
Microcontroller does not have a way to achieve sync'ed inverse PWM that I am aware of hence the need for external hardware.
Other method is to control 2 outputs using blink without delay style programming.
CrossRoads
dre3rd
Problem solved.  According to additional info I found at another website, this led has built in IC.
Hooked up again and it works.  Gnd and D13.  Don't know why it didn't work at first.
Lesson learned.  Try it more than once before asking for help.
Thanks again for the replies and for the birthday
Dan :smiley-red:
Paul__B
Do not power it with more than 4 or 5 volts at most - through a resistor.
If you have specs on it - always the best way - follow them carefully regarding current limiting and voltage.  Because the colour is changing, it does this internally using PWM and if you are driving it with too much current or too much voltage, it is quite easy to overheat them and they can have a short working life.
Some mice I bought years ago had just a current limiting resistor from 5V and burned out quickly.  I replaced them with others - more a "flashing" version than "fading" - with a couple of diodes in series instead of (or was it as well as?) the resistor and they are still going - flashing.
adell
Hi Dan,
Coming back to this subject
Can you share more details on how you managed that.
I have RGB Lights in a Pool too and there is a big Controller in the Room
I want to use Arduino to control it remotely
thanks a lot
my email is   adell@live.fr
Paul__B
Hi Dan,
Hello Adell.
Suggest you hop into your TARDIS and send him a PM.
