Topic: Project 5 - need help (Read 2899 times) previous topic - next topic
happymutant
Hi all,
I'd really appreciate some help with project 5 - I'm guessing I'm missing something big.
Here's my code:
// include the servo library
#include <Servo.h>
Servo myServo;  // create a servo object
int const potPin = A0; // analog pin used to connect the potentiometer
int potVal;  // variable to read the value from the analog pin
int angle;   // variable to hold the angle for the servo motor
  myServo.attach(9); // attaches the servo on pin 9 to the servo object
  Serial.begin(9600); // open serial connection
  potVal = analogRead(potPin); // read the value of the potentiometer
  // print the value to the serial monitor
  Serial.print("potVal: ");
  Serial.print(potVal);
  // scale the numbers from the potentiometer
  angle = map(potVal, 0, 1023, 0, 179);
  // print out the angle for the servo motor
  Serial.print(", angle: ");
  Serial.println(angle);
  // set the servo position
  myServo.write(angle);
  // wait for the servo
  delay(15);
and attached is a photo of the board. I've tried a new motor, new wires, new pot,  new breadboard... same result.  The  servo just spins with no change if I rotate the pot. I've checked the pot with a multimeter, and am confident i have that right...
Really appreciate any advice!
many thanks
Leila
Roduino
Looking at the picture of the project, it seems the yellow wire from the servo is going to pin 10 & not pin 9. Is that so?
Cheers
happymutant
Thanks Roduino!
it is hooked up to pin 9.  any other thoughts?
Leila
Roduino
Check the data (centre) pin of the pot  is on the same side as  the wire to A0.
If your still using a pot from the kit, the pot that I used, I placed in the middle of the board , had 2 pins on one side  of the board & the centre(data) pin on the other side(ie. lower side of yours) , if yours is similar placement shoudn't the wire to A0  go on the othe(lower) side of the board??
If so see p23, re: middle row breaks connection.
Cheers
happymutant
THAT WAS IT!!! Oh Roduino thanks so very very much!!!! :)
