Topic: EEPROM (Read 2085 times) previous topic - next topic
baum
In theory, could I load a VERY small program into the EEPROM, and then, at a certain point in my code, load the program?
Ex.
I run my very complex program until a button is pressed. The arduino then loads this program:
Code: [Select]
void setup() {}
void loop() {}
(It's my null program, it does nothing and takes up 450bytes of space.)
Coding Badly
Why would you want to do that?
baum
Quote
[glow]In theory,[/glow] could I load a VERY small program into the EEPROM, and then, at a certain point in my code, load the program?
I never said I did.
mowcius
It would be completely pointless... In theory you could make a cannon which fired toasters - not a lot of point to it.
You are better off just making them different looping functions and having the button as an interrupt to run some code to switch between them  ;)
baum
Quote
Do you just pull these ideas at random out of thin air?
Yes, I did. I pressurized the air in my house and put into a sealed flask with this:
http://www.sparkfun.com/products/10221
As the air evaporated, the levels were fed from the sensor to my arduino, which output the data as ASCII.
PaulS
Quote
Yes, I did.
Good thing you told us. I was beginning the think you'd pulled them from somewhere else.  ;)
