Topic: [ATTINY85]Nothing but junk appears on my serial monitor... :( (Read 8276 times) previous topic - next topic
Spyrakos88
Hello! I have an attiny85. I have flashed it with blink and is working well.
The problem is with serial. I burned the bootloader to use serial with no errors. I have tryied differnent cores with differents ide's with no success. I still getting junk letters from the serial . I used arduino duemilanove as isp . Is it possible the chip has failed and only serial doesnt work?
I also removed the atmega from arduino and replaced the capacitor with a jumper wire.Thanks
cjdelphi
There are no hardware serial ports.
Use softwareSerial over 3v  (5v)
Spyrakos88
Thanks for the reply!! Do you mean to power the attiny with 3 volts?
cjdelphi
Under 3.3v softwareSerial acts up (when powering the attiny85)
Spyrakos88
Thanks! The attiny was powered with 5 volts :( but i can't check it right now if it is working with 3.3 volts. I think that if i use the arduino 3.3v output i can get some readable data from serial. I will reply in about 4 hours..
Erni
If you use this core:
https://code.google.com/p/arduino-tiny/
there are several options for serial output.
A simple example below.
The serial output will be pin PB3. Connect a serial/USB converter to that pin.
This might be of interest:
http://www.ernstc.dk/arduino/tinycom.html
Serial.println("Testing..");
Spyrakos88
I just tested with 3.3 volts from arduino duemilanove and i get the same junk letters...with this code for example which uses the previous core i get this "ðððððððúððððððððûðððððððððððððððøððúððððððøððúððððððððð" in straight line.
Is there any problem that windows isn't in english language? I think i have tryied everything...
Erni
How are you connecting the tiny to your Arduino.
Why are you powering the tiny with 3.3V
Spyrakos88
Hello my friend here is the tutorial that i used.http://www.instructables.com/id/Program-an-ATtiny-with-Arduino/
I succesfully flashed it with blink sketch but with serial... no luck!
I powered with 3.3volts because today i learned that serial working only under this voltage. But with both voltages i keep reaciving
these letters.
Now im thinking if the problem is the chip itself or the duemilanove...
I accept any help thanks
Erni
That proves that you should not trust everything you read, it is nonsens.
I don't know the core you are using, as I said in previous post I am using this one:
is there any problem that windows isn't in english language? I think i have tryied everything...
No mine windows is danish, and that dosn't give me any trouble.
Are you using SoftWareSerial for communication ?
Spyrakos88
Are you sure about that? I left that as a final solution (before i throw it to the garbage)because it has a lot of reading. So there are attinys that are ok and some others that need this "calibration"?? Bad luck then...
Spyrakos88
Thanks my friend. I cant check it right now because i need to read several things about that (im using attiny for first time) and i will reply asap.  I found pour man's tiny tuner. Is that the way to go or you have a better-faster way?
