Topic: Supply from China, suggestions please? (Read 8281 times) previous topic - next topic
seratechi
Sure, my apologize for the rash statement. We are working on the library now, thanks!  :)
HULK
#16
Oct 14, 2008, 09:59 am Last Edit: Oct 14, 2008, 10:04 am by HULK Reason: 1
Eric,
Another thing i am looking for is a project box.
It should be black and in metal such as aluminum or some other light metal with a good finish.
Size should be according to link below.
http://www.bopla.de/uploads/tx_commerce/mediando/P_Zeichnungen_PDF/84080100__2801326.pdf
This may be hard to find, but nothing wrong in asking.  ;)
The brand of this box is Bopla and model is Alubos 800, nice quality but way to expensive (20Euro).
http://www.bopla.de/en/product-catalog/enclosure-technology/product-category/alubos-2.html
seratechi
HULK - I'm afraid there is not going to be exactly same case, but there are some shell for hardrivers are fancy and elegant too. Let me check them out and reply later. Very nice selection! ;)
seratechi
I don't find such small case with water-proof rubber, but there are really some good cases from our supplier. Here is a close one:
http://www.seeedstudio.com/depot/aluminium-case-for-small-projects-p-154.html
HULK
#19
Oct 16, 2008, 03:19 pm Last Edit: Oct 16, 2008, 03:26 pm by HULK Reason: 1
Eric,
That one is nice, i like it. I could color it black if i want to my self and make the lenght of it shorter by cutting.
But i need the inner dimensions of the box to be at least 25mm wide and 70mm high. Will be hard to mount my lcd i have ordered in that box.
If this is the lcd i have put an order for from you it is 70mm high.
http://www.topwaydisplay.com/Pub/Drawing/MK-001734a-1-1(LM12864LDW%20Outline).pdf
If not, could you provide me with the dimensions for the lcd i ordered so i can check?
In the box i also need to fit a ATMega 644 and accelerometer module therefore i need it to be 25mm wide.
See my problem?
seratechi
The LCD you ordered is 92mm*70mm*12mm, you may want to give me a range of internal dimension that I'll ask the supplier for a fit one.
Looking forward to see your project whenever finishes;D
HULK
Eric,
Then i would need the inner dimensions to be at least 95mm*70mm*25mm.
Give me feedback with sizes you can provide and i will select one, if it could be exactly 95mm*70mm*25mm that would be good.
Give my project a month or so and it should be up and running in my car with the parts you have provided me with  :)
follower
Hi Eric,
So, I'm not promising I'll buy them if you stock them :) but I'm curious about the price/availability/minimum quantity of the following:
1) "Joystick" style mini-switches (4 way + push) like those here. In order of preference: TSJ 31, TSSJ 30, TSSJ 5.
2) Tiny square-ish monochrome dot matrix LCD--"Tamagotchi" size or like this or this.
Thanks.
--Phil.
seratechi
HULK - There are countless dimensions, and customized manufacturing is possible. But for <10 pcs, I have to check the market for ready-to-go samples. Here is one might meet your requirement: http://www.seeedstudio.com/depot/aluminium-case-for-small-projects-1138035-mm-with-ears-p-155.html
And the LCD is arrived, we have lit it to validate. It's exactly the same with the one your ordered, but pure gray indeed.: http://www.seeedstudio.com/depot/graphic-lcd-12864-ks0108-ctrl-white-and-dark-gray-p-152.html
Phil - Thanks for the inquiry. We are now increasing our stock, so it would be greatly appreciated for suggest your demands, we don't consider it an obligation to order at all. ;)
1) There are very wide selection of these joysticks here, I'll choose some kind with great quality and list them.
2) I have seen these small LCDs, likely 128*128. They are usually FPC plugs, we will supply some jack for it whenever sourced.
HULK
Nice products as usual Eric,
Could you update the status of the LCD so i can order, your site is saying sold out. Hope nobody managed to buy it before me  :).
I will order one of each boxes you have now and see which one pleases me best. But for now no need for customized manufacturing.
HULK
Eric,
I think you could add listed things below to your stock.
Chips:
ATMega 328
ATMega 644
Buttons such as high quality once in metal, off/on or off - (ON)
Maybe some packages with mixed resistors, capacitors, connectors and so on.
HULK
#26
Oct 18, 2008, 11:09 am Last Edit: Oct 18, 2008, 11:09 am by HULK Reason: 1
This link will show you a good example of mixed component packages, language is not english but i think you will understand.
http://www.kjell.com/content/templates/shop_main.aspx?catalog=201440&path=239000000,272500000,275000000
seratechi
HULK - Thanks for the suggestions, we will record it as plan too! :)
HULK
I will try to share more ideas of mine for your store with time.
By the way, i have completed a new order with the new things you have sorced for me .
Now i just need to wait for two packages from China  :)
seratechi
follower - Please take references of these, MPQ=0:
Joystick switch - ALPS original, premium quality. cheaper ones available upon request :
http://www.seeedstudio.com/depot/alps-skqu-4-direction-joystick-w-switch-p-161.html
128 * 128 panel - I don't run into smaller square ones with available small sample, 1k+ will be enough for customization:
http://www.seeedstudio.com/depot/graphic-lcd-128128-cog-panel-p-162.html (this one is a bit complex through)
HULK - Metals buttons are really awesome... If not for the cost, I would definitely make a monome with the LED ones myself ::)
http://www.seeedstudio.com/depot/ip65-metal-push-button-momentary-p-159.html
http://www.seeedstudio.com/depot/ip65-metal-push-button-momentary-w-blue-led-p-158.html
