the only way that the Yun will work is to us the IP number! The issue is that I would like to not have to remember my ip number or if I take the Yun to a new location I don't want to have to find look it up so I want to use http://arduino.local but it never woks. Is this a router issue? or a Yun issue?
If I unplug my internet cable from my router it works! So I think its a router issue, can someone give me advice on what settings I should look at in the router?
Sorry, sonnyyu but I do not know how to install this package! The last time I installed anything I used the Arduino-Software install package from the control panel. But the "nss-mdns_0.10-1_ar71xx.ipk" is not in the available packages.
So If I put the package on the sd card how would I install it with putty ?
Thanks
Sonnyyu's answer will let your yun find other devices broadcasting zeroconf info. I think you want to find the yun with your Windows box, if so you need Apple's print services Download Bonjour Print Services for Windows v2.0.2
To answer you present question, you can install a package on your SD card with opkg install /mnt/sd/somepackage.ipk
Ok now I can not log in to the Yun's control panel again!!! I guess I have to reset again what a pain! Is it me or should this thing just work out of the box like the set up file "http://arduino.cc/en/Guide/ArduinoYun#.UxEMPvmwL3s" say's?
Ok sorry for the rant I have been missing with this for days I will reset and try everything again.
If it was not for people helping, I would have just gave up and went to something else.
Thanks for you help.
I have installed "nss-mdns_0.10-1_ar71xx.ipk"
and I have uncomment the line /etc/avahi/avahi-daemon.conf
host-name=arduino
domain-name=local
But that did not work I still can not go to http://arduino.local I have to goto the ip address "192.168.1.103"
But like I said I can unplug the internet cable from the router and it works.
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\chris_000>ping http://arduino.local
Ping request could not find host http://arduino.local. Please check the name and
try again.
C:\Users\chris_000>
C:\Users\chris_000>ping arduino.local
Pinging arduino.local [69.16.143.110] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 69.16.143.110:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\chris_000>
Here you can see that the IP is not right it should be 192.168.1.103
Thank you that worked now I can use arduino.local
If anyone else is interested here is What I did:
go to c\Windows\System32\Drivers\ folder on a Windows computer
right click on folder etc and uncheck "Read-only" then "apply"
In the etc folder you will find file "Host"
right click on "host" choose "Properties"
go to the security's tab
Select edit to change permissions
in the "Group or user names" select the user that you are login as mine is "User (Chris\Users)"
Then in the "permissions for User" check box "Full Control" then -"OK"
Now open "host" with a text editor like wordpad
At the end of the file add
"your arduino IP address" arduino.local
mine is "192.168.1.103 arduino.local"
Save the file
Undo changes to permissions of host file (uncheck "full control and Write")
That's it it takes about a min for it to update then you can use "arduino.local"
Arduino's default is DHCP client, every time it could have new IP address.
To make your solution to work, following either condition have to meet:
Setup Arduino as static IP
If router support mac address IP address binding, then binding static IP with Arduino Mac address
Yes that would be a problem every time that my router gives a new address I would have to do everything all over again!
Thanks what would be the downside of setting the Arduino as static IP?
I have followed your post and have uninstalled Bonjour and reinstalled
I have meet both conditions
Yun in IDE Port menu need to meet 2 conditions:
1. Yun Bonjour service is working.
2. Windows' UDP port 5353 is open.
And I can see _arduino._tcp (Arduino) in the Bonjour browser and here is the ping request
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\chris_000>
And I still can not use http://arduino.local
Is there a plan c or could something be wrong with my Yun?
Thanks again!
