Topic: How to use xbee or other thing base on TTL? (Read 872 times) previous topic - next topic
zixzixzix
Mar 01, 2014, 04:22 pm Last Edit: Mar 01, 2014, 04:32 pm by zixzixzix Reason: 1
I can ues my xbee on arduino uno very well.
but i canot use it on arduino yun for the same code.
Code: [Select]
 // Analog input pin that the potentiometer is attached to
        // value read from the pot
String val = "";
  // initialize serial communications at 9600 bps:
  if(Serial.available()>0){
  val+= char(Serial.read());
  delay(100);
  Serial.println(val);
  Serial.flush();
  val="";
PCWorxLA
Common issue, your code uses the serial port of the Uno, that will not work on a Yun, as the serial port is used for the bridge between the two different parts (MIPS/AVR) of a Yun...
Ralf
zixzixzix
PCWorxLA
Thank you.
So I must use soft serial?
Yup, that's the most likely alternative...
Ralf
