Topic: 2.4 inch TFT touch LCD Screen Module For Arduino UNO R3 SD low price jocks (Read 215922 times) previous topic - next topic
casemod
It's the hardware peripheral available on MEGA2560 micros, called "external memory interface". The WR, RD, ALE pins  are manages automatically, no need to set/clear these pins by program. It is designed for connecting more SRAM directly to the uC.
In the code, display memory is then addresses with pointers, exactly the same way as internal RAM. I have used that a long time ago to interface displays with 8051 micros; it should work here also.
Anyway, by using the latest Adafruit library, it is faster than before (~2x).
I'm looking at this just now (complete failure getting the code to run on a due!!)
Did you managed to check anything related to the subject?
McAndrew
I have that tft from a few days ago and am having problems with it ...
When the coupling to the Arduino UNO, lights (all normal), but when I go to load the sample program "paint" or any of them, it shows nothing, it just stays lit.
I tried the "touchscreen" and "Paint" program and open the ternimal coordinates and shows me when I play, but as I say, nothing appears ...
I tried to delete all the libraries and leave only those taxes to use, so there were no problems with duplicate libraries, but does not work.
Do you guys have any idea ?.
Thank you.
casemod
Thank you.
Post a photo.
I have 3 and one is problematic (different controller) so this could be the case.
What does the program report as the controller trough the serial port?
McAndrew
ok,
Here is what appears on screen ...
Here what appears with touchscreen
With Graphictest
I have seen that in the serial monitor, LCD Driver chip appears: 7777.
Can that be the problem that nothing appears in it?
casemod
That s the right identifier. S77xx Family.
Try the code attached below. Delete all the other libraries in use and report.
McAndrew
Thanks for trying to help me, but still not working... :~
The software version is 1.0.5-r2
casemod
Install a fresh 1.5 and try again. Use the version below, extract to a folder and run the arduino executable (You can simply delete the folder when you are having trouble with something and extract from the archive again).
http://downloads.arduino.cc/arduino-1.5.7-windows.zip
Technically it should work, if not maybe there is some sort of problem with the screen itself.
McAndrew
Definitely does not work ...
I'll try to buy another screen tft and another arduino...
Now see this:
Arduino: 1.5.7 (Windows 7), Placa:"Arduino Uno"
C:\Users\Andres\Downloads\arduino-1.5.7\libraries\TFTLCD\glcdfont.c:9:23: error: variable 'font' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static unsigned char  font[] PROGMEM = {
I have to change something?
That TFT recommend me to buy?
Thank you.
casemod
Hum... Im getting that sort of errors myself on the new arduino. Try to download version 1.5.6 instead. Less buggy.
I quite like that particular TFT to be fair, Shame it didn't work out for you
Whatever you buy don't get anything with the ILI9327 Controller in 8 bit mode. I am yet to find a suitable library.
ILI9320, ILI9325, SSD1289 are all good candidates, just be aware that the chinese guys often mislabel them. I would be aware buying anything that says mcufriend.com - These displays are mostly sold with the wrong model and the seller wont be able to help you. This was an issue with this red TFTs a while ago.
bricofoy
to solve this particular issue, just add the "const" keyword to the function definition in glcdfont.c
you will got something like const uint_8 font[]=.......
-tu savais que si tu passe le CD de windows à l'envers, tu entends une chanson satanique ?
-non, mais il y a pire : à l'endroit, ça l'installe !
McAndrew
It is the first time I work with the arduino platform and still do not understand very well ... How do I do that?
casemod
How do you do what?
McAndrew
this...
casemod
this...
You should have a field named "uint_8 font[]=....... "and you add the word const to it:" const uint_8 font[]=......."
I haven't used that particular one, so I am sure  bricofoy can clarify if you still dont find it.
bricofoy
yes. the problem with 1.5 is they've changed some compilation option (or compiler version, I don't know) wich now causes the error above, and stops compiling. So as the error messages explain, the font[] variable must be declared as "cosnt", so the workaround is quite simple : go to the library folder, open the file named in the error message, and change the font declaration to meet the requirement.
