2.4 inch TFT touch LCD Screen Module For Arduino UNO R3 SD low price jocks
Pins in out this really now all to work?
Poll resistors screen
and
immediately output to the screen simultaneously,
it is now so fashionable?
i to write code to work
//20140208 art100  tft2.4" st7783 shield on arduino uno
// art100 write message
//#include "st7783SD.h" // pins SD_SS-10 SD_DI-11(in) SD_DO-12(out) SD_SCK-13 no work
//#include "st7783TFT.h" //has not written
//#include "st7783TouchScreen.h" //has not written
#include "TFTLCD.h" // work
#include "TouchScreen.h" // bad but it works
//TouchScreen define
#define YP A1 //tftloop-YU pcbundertft-13 arduinoshieldLCD_WR!!! arduinouno-A1
#define XM A2 //tftloop-XR pcbundertft-14 arduinoshieldLCD_RS!!! arduinouno-A2
#define YM 7  //tftloop-XR pcbundertft-15 arduinoshieldLCD_D7 arduinouno-7
#define XP 6  //tftloop-XR pcbundertft-12 arduinoshieldLCD_D6 arduinouno-6
#define TS_MINX 150//0
#define TS_MINY 120//0
#define TS_MAXX 920//900//320      //for calibrate analog resistans ~1500om/700om
#define TS_MAXY 940//800//900//240 //for calibrate analog resistans ~1500om/700om
// For better pressure precision, we need to know the resistance// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
//TFT  define
#define LCD_RESET A4//
#define LCD_CS A3
#define LCD_CD A2 //cmosbuffer-arduinoshieldLCD_RS!!! arduinouno-A2 this is jock :-?
#define LCD_WR A1 //cmosbuffer-arduinoshieldLCD_WR!!! arduinouno-A1 this is jock :-?
#define LCD_RD A0
// Color definitions
#define WHITE           0xFFFF
#define	BLACK           0x0000
#define	RED             0xF800
#define	BLUE            0x001F
#define	GREEN           0x07E0
#define YELLOW          0xFFE0
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
//SD define //has not written
#define bordur   5
#define pen      3
void setup(void) {
  Serial.println("Paint");
  tft.reset();
  uint16_t identifier = tft.readRegister(0x0);
  tft.initDisplay();
  tft.fillScreen(RED);
#define MINPRESSURE 10    // analog calibrate
#define MAXPRESSURE 1000  // analog calibrate
void loop(){
  Point p = ts.getPoint(); // get analog point
  pinMode(XM, OUTPUT); //2 chip on one pins
  pinMode(YP, OUTPUT); //2 chip on one pins
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) { // analog calibrate
    p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width ()); // aprocsimate variable
    p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height()); // aprocsimate variable
//    if (300< p.x) { // erase only on bordur  //no need have reset button
//      Serial.println("erase"); // test
//      tft.fillRect(0, 0, tft.width(), tft.height(), RED);// BLACK); //fill black
    // test
    Serial.print("getPoint x=");Serial.print(p.x);Serial.print(" y=");Serial.print(p.y);Serial.print(" PRESSURE=");Serial.print(p.z);
    // paint
    if (((p.x)<tft.width()) && ((p.y)<tft.height())) { tft.fillRect(p.x,p.y,pen,pen,GREEN); }
Need critique of the code?
