Topic: [SOLVED]Yun + Solar w/12v Battery (Read 8714 times) previous topic - next topic
theDuke540
Mar 09, 2014, 10:49 pm Last Edit: Mar 20, 2014, 09:28 pm by theDuke540 Reason: 1
  I've been messing around with the yun for around a month now so I'm by no means an expert with it. However, my current project requires solar power since the yun will be in a remote area. I have an ASC solar voltage regulator which takes ~14v from my Aleko solar panel and charges a 36Ah battery.  From the battery I have a 5v Buck converter I got from adafruit that feeds 5v to an Arduino. The catch is, when I connect the 5v to my Vin pin, nothing happens. I've got a good ground and I've verified the voltage from the converter. Is there something I'm missing? Also I've verified this issue on another yun and same results. Any help is greatly appreciated.
theDuke540
So I've taken pictures in hopes that ANYONE will be able to steer me in the right direction with this. I'm at my wits end because I can't understand why this won't work.
This is the wiring on the breadboard: the red on left is 12VIN, middle is ground from battery and to arduino, and the red wire on right is 5Vout. For the Yun, the 5Vout from regulator is going to VIN pin and ground is to ground.
This is the 5Vout from the regulator:
As usual, any help is greatly appreciated. Also, both Yuns I have work fine with microUSB input power.
bjarne
Have you verified that you get 4.6V or more on the 5V (out) pin?
It is hard to make out the actual connection to the Yun on your picture, but I assume you have triple-checked  :)
bjarne
And how do you know that it does not work, what are the symptoms?
You don't by any chance have the old 'while(serial)' in your setup() ?
theDuke540
Sorry about the picture's angle. I actually checked a little while ago and I'm only getting ~1.4V out of the 5V pin. Seems like something is wrong there. I verified this on two separate Yuns though.
The red wire is VIN on the yun and the black is GND.
I know it's not working because the 'ON' LED doesn't illuminate. (not trying to be a smart-a**) Other than that, I haven't even connected anything to it because I didn't see the light. No sounds, no nothing. :0
I don't use any old syntax, at least if i can help it  :smiley-roll-sweat:
Thanks for the reply.
bjarne
OK, it is always difficult to tell when you are not actually there, so excuse if the following is obvious.
There are two diodes between Vin and +5V out, so the output voltage can not be 1.4V if the input voltage is 5V, so I have to ask if you measured the 5V on the Yun itself.  In the picture it looks to me like you are measuring the 5V while it is not connected to the Yun, is that true?  Maybe you don't get 5V when it is loaded with the Yun, I would measure the voltage on the pins of the Yun to be sure.
theDuke540
In the picture I was in fact measuring 5v while disconnected. Later on, I had the bright idea of measuring the Vout from the 5v pin. Here is a pic of the 5v(Vout) from the Arduino. (I was wrong, it was ~1.19vdc):
Here is a different pic of the Yun input and output wiring. The jumper wires are output(5v & GND) and the regular wires are VIN & GND:
Once again, thank you for taking the time out of your day to help me.
bjarne
It is still not clear to me, have you measured Vin while connected to the Yun, preferably on the Vin pin of the Yun itself? I have to believe that you will find it to be around 3V.
theDuke540
Sorry about that. I guess I misunderstood your request earlier :~. I just measured VIN on the Yun and it's 1.34V.
bjarne
Ah, makes sense.  I guess your regulator circuit can not handle the load.
theDuke540
It's a 5v, 1A regulator though. There are no components connected so theoretically the load should only be about ~250-270mA. I suppose I could try a different regulator but this just doesn't make sense to me.
bjarne
What is the voltage at the input of the regulator, when the Yun is connected?
theDuke540
I'm using a 12v marine battery, so the input to the regulator (on a full charge) is about 12.9vdc (+/-0.5v). The input to the regulator when the Yun is connected is 12.83vdc.
bjarne
And you actually measured it with the Yun connected?  Maybe the battery isn't charged?
