Topic: Short Range Wireless Communication (Read 4356 times) previous topic - next topic
weableandbob
Mar 10, 2014, 06:38 pm Last Edit: Mar 10, 2014, 09:07 pm by weableandbob Reason: 1
I was wondering if anyone had any suggestions for an Arduino (Nano) compatible solution for short (ideally ~15 feet) wireless communication, either between two Arduinos or an Arduino and a phone. The two obvious solutions are either Bluetooth or an RF module, but both seem to have too great of a range. According to here, the shortest range Bluetooth radios have a range of approximately 3 feet (too short), and the next step up has a range of approximately 30 feet (too large). RF modules that I've been able to find, such as this one, also seem to have ranges that are too large (for that one, it's supposedly 300 feet, but reported to only really be 100 feet).
Edit: The two devices need to be able to communicate without a line of sight.
Zapro
Use Infrared. With a cluster of LED's pointing all ways, you can quite easily cover a pretty big area.
// Per.
weableandbob
// Per.
Sorry, I should have specified in the original post that the two devices need to be able to communicate without a line of sight.
Zapro
If they are in the same room, Infrared is still possible.
In stores here in Denmark, we have electronic price tags on the shelves in some supermarkets. They are programmed and updated via Infrared light, and in a store, there isn't many "emitters" in the ceiling - they just rely on reflections from other parts of the room. There is no need to have line of sight.
// Per.
CrossRoads
CrossRoads
5V compliant IO, power needs to be 3.3V.
pito
Quote
Then it is easy - use ie. HC-05 and you will get aprox 15feet "without a line of sight"..
:P
weableandbob
Check into nrfl2401 transceivers.
http://yourduino.com/sunshop2/index.php?l=product_detail&p=188
Looking at Google results, it looks like the max range for those is approximately 200 feet at 250 kbps, although I assume that was tested on the maximum power output of 0 dbm. Do you know how much lower it gets when adjusted to -6/-12/-18 dbm?
CrossRoads
