Topic: MOVED TO YUN: Process.runShellCommand - Shell program executed repeatedly (Read 1 time) previous topic - next topic
chriddyplz
Hi all --
A shell program that I'm executing with runShellCommand(...) seems to run repeatedly, rather than run once.
Code: [Select]
#include <Process.h>
 Bridge.begin();   // Initialize the Bridge
 Serial.begin(9600);   // Initialize the Serial
 Process p;
 p.runShellCommand("/root/shell_example.sh");
 while (p.running());
 while (p.available()) {
 delay(5000);  // wait 5 seconds before you do it again
void loop(){}
On the linino, we have this file in /root called shell_example.sh:
Code: [Select]
#!/bin/sh
INCR=0
while [ 1 ] ;
   do
       touch test$INCR
       sleep 1
       rm test$INCR
       INCR=$((INCR+1))
   done
This file just creates a file named testi every second, and increments i, e.g. test0, test1, test2, test3, ...
When I run the Arduino code, a file named test0 is created every second, in `/usr/lib/python2.7/bridge` (where bridge.py exists), as if the `shell_example.sh` was being called every second.
So what's going on with the runShellComand? Does it repeatedly call the command?
In processes.py in /usr/lib/python2.7/bridge, I'm assuming that command
Code: [Select]
proc = Popen(cmd, stdout=PIPE, stderr=PIPE, stdin=PIPE)
is being invoked. But opening up python in that directory and running
Code: [Select]
>>> from subprocess import Popen
>>> Popen('/root/shell_example.sh')
<subprocess.Popen object at 0x77bf05f0>
does the right thing: test0, test1, test2, ... get created.
So, I'm assuming that the `cmd` is being garbled somehow. I tried to write the command to a file by modifying the source of `processes.py`:
Code: [Select]
__future__ import print_function
class Processes:
 def __init__(self):
   self.processes = { }
   self.next_id = 0
 def create(self, cmd):
   # Start the background process
   try:
     f = open('writing_cmd', 'a')
     print(cmd, file=f)
     f.close()
But no file was written.
Any ideas why this shell program isn't being executed correctly?
sys64738
Hi
the shell script you created runs in an endless loop.
Is that what you wanted?
You should explain what you want to do.
Regards
sys64738
