Topic: MOVED TO YUN: Using Process.runShellCommand to start Python Program (Read 837 times) previous topic - next topic
chriddyplz
Mar 12, 2014, 04:26 am Last Edit: Mar 12, 2014, 04:29 am by chriddyplz Reason: 1
Moved to the Yun forum: http://forum.arduino.cc/index.php?topic=225229.0
Hi all --
I'm trying to start a python program on the Linino from the Arduino. This is what I've got:
Arduino Code
Code: [Select]
#include <Process.h>
 Bridge.begin();   // Initialize the Bridge
 Serial.begin(9600);   // Initialize the Serial
 Process p;
 p.runShellCommand("/root/run_my_python.sh");
 // do nothing until the process finishes, so you get the whole output:
 while (p.running()){ ; }
 while (p.available()) { ; }
 delay(5000);
void loop() { }
On the Linino, in a file called run_my_python.sh in /root:
Code: [Select]
#!/bin/sh
python /root/my_python_program.py
On the Linino, in a file called my_python_program.py in /root:
Code: [Select]
import os
os.system('touch /root/touched')
When I run
Code: [Select]
$ /root/run_my_python.sh
in the terminal, a file in /root named `touched` successfully gets created. However, when I run this from the Arduino, no file gets created. What am I doing wrong?
Perhaps this is related to some other issues I observed with runShellCommand, here: http://forum.arduino.cc/index.php?topic=225205.0
Thanks a bunch!
