Topic: Stepper motor controller and arduino (Read 12192 times) previous topic - next topic
ACrespin124
Hahaha my code was kind of a test for the motor and the driver, but your code easily separates variables for adjustment in a way that I've been wondering how to do myself.  Just learned a little something new in the process :)
I've come across an even worse problem now, I tried Verifying my old code that worked from before and now it's giving me this error which I know others have had before but I can't find the answer to it.
at java.util.regex.Pattern$GroupTail.match(Pattern.java:4717)
at java.util.regex.Pattern$BranchConn.match(Pattern.java:4568)
at java.util.regex.Pattern$CharProperty.match(Pattern.java:3777)
at java.util.regex.Pattern$Branch.match(Pattern.java:4604)
at java.util.regex.Pattern$GroupHead.match(Pattern.java:4658)
at java.util.regex.Pattern$Loop.match(Pattern.java:4785)
The previous "working" code is actually below (next post, won't let me post in this one) but I removed the second motor block since it was giving me trouble with the move back and forth.
Robin2
That Java problem is because whoever wrote the Arduino IDE did not trap all possible errors correctly. There is some mistake in your code that Java is choking on. You will need to read through your code very carefully. Perhaps make a copy of your code and then delete chunks to isolate where the choke point is.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
ACrespin124
WOOT! I found the error after reading all lines of code that I had modified...
So now I'm back to square one: my code worked and yours didn't on the board, but I'll make a diagram to show my wiring exactly how I have it.
 Here's my code:
Code: [Select]
#include <Keypad.h>
// Define the states for the lock state machine
#define LOCKED 2
#define UNLOCKED 0
// State Variables:   Initialize to the locked state
int LockState = LOCKED;
long StartTime = 0;
int position = 0;
int Distance = 0; //Record steps
// Define your password key sequence here
char* secretCode = "2301000";
// Keypad key matrix:
const byte rows = 4;
const byte cols = 3;
char keys[rows][cols] =
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
// Keypad pin definitions
byte rowPins[rows] = {5, 6, 7, 8};
byte colPins[cols] = {2, 3, 4};
// Instantiate the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
int transistorPin = 9; //LED Transistor Pin Definition
int StepperDistance = 10; //Stepper Distance Pin Definiton
int StepperDirection = 11; //Stepper Direction Pin Definition
int StepperStart = 12; //Stepper Engage Pin Definition
int ColorLED = 13; //Color LED Definition
Adafruit_NeoPixel IndicatorLED = Adafruit_NeoPixel(2, ColorLED, NEO_RGB + NEO_KHZ800);
//400 IS FOR WS2811 and 800 IS FOR WS2812
  //Set stepper and Light Parts as Outputs)
  pinMode(transistorPin, OUTPUT);
  pinMode(StepperDistance, OUTPUT);
  pinMode(StepperDirection, OUTPUT);
  pinMode(StepperStart, OUTPUT);
  //Set stepper settings off and Clockwise
  digitalWrite(StepperStart, LOW);
  digitalWrite(StepperDistance, LOW);
  digitalWrite(StepperDirection, LOW);
  // Initialize state of lock and communications.
  setLockState(LOCKED);
  IndicatorLED.begin();
  IndicatorLED.show(); //Initialize LEDs to 'off'
  // Run the state machine:
  // Locked State - Monitor keypad for valid Password code entry
  if (LockState == LOCKED)
    char key = keypad.getKey();
    if (key == '*' || key == '#')
      position = 0;
    if (key != 0)
      if (key == secretCode[position])  // Valid key in Password sequence
        Serial.print("Matched ");
        Serial.print(key);
        Serial.print("-at-");
        Serial.println(position);
        position ++;
        IndicatorLED.setPixelColor(0, 255, 0, 0);
        IndicatorLED.setPixelColor(1, 255, 0, 0);
        delay(10);
        IndicatorLED.setPixelColor(0, 0, 0, 0);
        IndicatorLED.setPixelColor(1, 0, 0, 0);
        //Green LED flash
      else  // Invalid key - start all over again
        Serial.println("Invalid Code!");
        position = 0;
        IndicatorLED.setPixelColor(0, 0, 255, 0);
        IndicatorLED.setPixelColor(1, 0, 255, 0);
        delay(100);
        //Red LED on for 2 seconds
    if (position == 7)  // Password successfully entered - advance state
      setLockState(UNLOCKED);
      position = 0;
    delay(100);
// Set the state and the time of the state change
void setLockState(int state)
  LockState = state;
  StartTime = millis ();
  if (state == LOCKED)
    Serial.println("Locked!");
  else if (state == UNLOCKED)
    Serial.println("Unlocked!");
    //MyStepper.step(STEPS);
    digitalWrite(StepperStart, HIGH);
    delay(25);
    digitalWrite(StepperDistance, HIGH);
    delay(100);
    //Code for 90 degree clockwise turn below... 1:1 stepping ratio, no chopping
    if(Distance < 90);
      delayMicroseconds(100);
      Distance = Distance + 1; //Record this Step
      Serial.println("Stepped!");
    for (int brightness = 0; brightness < 255; brightness++) {
      analogWrite(transistorPin, brightness);
      delay(12);
    rainbow(12); //Start flashing Rainbow LEDs
    IndicatorLED.setPixelColor(1, 0, 0, 0);  //0, Begin Rainbow Countdown to Close ROYGBP
    IndicatorLED.setPixelColor(1, 0, 255, 0);  //RED
    delay(100);
    IndicatorLED.setPixelColor(0, 100, 255, 0);
    IndicatorLED.setPixelColor(1, 100, 255, 0);  //ORANGE
    delay(100);
    IndicatorLED.setPixelColor(0, 255, 255, 0);
    IndicatorLED.setPixelColor(1, 255, 255, 0);  //YELLOW
    delay(100);
    IndicatorLED.setPixelColor(1, 255, 0, 0);  //GREEN
    delay(100);
    IndicatorLED.setPixelColor(0, 0, 0, 255);
    IndicatorLED.setPixelColor(1, 0, 0, 255);  //BLUE
    delay(100);
    IndicatorLED.setPixelColor(0, 0, 255, 255);
    IndicatorLED.setPixelColor(1, 0, 255, 255);  //PURPLE
    //Fade off the Light
    for (int brightness = 255; brightness >= 0; brightness--) {
      delay(20);
    //Close Cabinet
    //Indicate the code will return to locked state
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for (j = 0; j < 256; j++) {
    for (i = 0; i < IndicatorLED.numPixels(); i++) {
      IndicatorLED.setPixelColor(i, Wheel((i + j) & 255));
    delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if (WheelPos < 85) {
    return IndicatorLED.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if (WheelPos < 170) {
    WheelPos -= 85;
    return IndicatorLED.Color(255 - WheelPos * 3, 0, WheelPos * 3);
    WheelPos -= 170;
    return IndicatorLED.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Robin2
Here's my code:
That is very long compared to mine :)
If this code makes your stepper move more than one step then your driver must be very different from the type my code is intended for
Code: [Select]
    delay(25);
    delay(100);
If this code does make you stepper move multiple steps please post a link to the datasheet for your stepper driver.
...R
