Morning all,
I am working on a project in which I want to communicate with a k-line module. I have been successful in communicating with it over k-line with an off the shelf tool, but now want to incorporate it into a larger project. I have the parameters for the communication, and they are definitely not standard. It seams that my go-to automotive all in one solution (Elm327) does not support all the features I need.
I was looking through the forums and online and found this to handle the physical layer. can anyone comment on what they think. I am not the strongest in hardware design but the logic of it makes me think it would work.
these are the protocol requirements:
I need to set the baud rate to 9600
I need to find a way to not append a checksum to the outbound message…. (think I got this easy)
I also need the P4 time (inter byte time) to be as low as possible (0)
Last thing is parity and frame length… needs to be 8 bits, even parity and 11 for frame length.
Thanks and any help/comments would be much appreciated. not sure if anyone has done something similar that I can use as reference from a hardware or program standpoint.
