Topic: Cant get Micro SD reader to initialise! (Read 1 time) previous topic - next topic
uobstudent
I'm using a MEGA2560 with the RAMPS mirco SD reader (link below) connected as follows
http://www.ebay.co.uk/itm/microSD-SD-Card-Reader-Module-SDRamps-Breakout-Arduino-Module-/141090241368?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item20d9a23b58
CS 53
SCK 52
SO 51
SI 50
With a 5v supply and Gnd (Board should convert it).
And this Code:
#include <SD.h>
File myFile;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
   pinMode(53, OUTPUT);
  if (!SD.begin(53)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    // close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
        Serial.write(myFile.read());
    // close the file:
    myFile.close();
    // nothing happens after setup
Any help be really grateful :)
uobstudent
My SD Card is a 8gb SDHC by Samsung formatted to FAT32 using a windows 7 PC
fat16lib
Your problem may be a wiring error.
SO on the module should be connected to Arduino pin 50, MISO, Master In Slave Out.
SI on the module should be connected to Arduino pin 51, MOSI, Master Out Slave in.
You say this is how they are connected.
Quote
SO 51
SI 50
uobstudent
raschemmel
Most of the SD cards (shields) that I have seen only work with FAT16 format.
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
