Topic: GSM Shield says SMS complete but message doesn't send (Read 12316 times) previous topic - next topic
stephenpperry
Hi, I'm using a gsm shield to send SMS messages, and I'm literally on the first step with the info at http://arduino.cc/en/Guide/ArduinoGSMShield
The strange thing is I've used multiple numbers in the
char remoteNumber[20]= "12125551212";
field and none of them receive a message from the arduino despite it saying
SENDING
Message:
Test
COMPLETE!
I'm using an 02 United Kingdom sim. Which has credit and isn't sim locked, I tried it in my phone and managed to send texts, but sir some reason can't get the arduino to do it.
Any thoughts would be greatly appreciated!
stephenpperry
Managed to sort it using instructions and script at http://arduino.cc/en/Tutorial/GSMExamplesSendSMS instead
davidgoth
You have to add your country code to telephone number (for example: +44123456789)
visualxl
I am facing the same problem!
I have also added the country code without success.
I am using the exact "sendSMS" sample. It was actually working yesterday without country code. I did not change anything.
Please assist.
Code: [Select]
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
GSM shield and SIM card, open the serial monitor, and wait for
the "READY" message to appear in the monitor. Next, type a
message to send and press "return". Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
* GSM shield
* SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
// Include the GSM library
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.print("Enter a mobile number: ");
  char remoteNum[20];  // telephone number to send sms
  readSerial(remoteNum);
  Serial.println(remoteNum);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNum);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
  Read input serial
int readSerial(char result[])
  int i = 0;
  while(1)
    while (Serial.available() > 0)
      char inChar = Serial.read();
      if (inChar == '\n')
        result[i] = '\0';
        Serial.flush();
        return 0;
      if(inChar!='\r')
        result[i] = inChar;
        i++;
davidgoth
Replace the line "GSM gsmAccess;" by "GSM gsmAccess(true);".
Then, you can see the commands of modem. Post the output.
visualxl
I did not replace the line "GSM gsmAccess;" by "GSM gsmAccess(true);
The SMS will only work if I bring up the Serial Monitor. If I were to supply external power to the BLUNO (Uno + BLE) without bringing up the Serial Monitor, the SMS won't work. Why is that so?
visualxl
I replaced it with
Code: [Select]
It solves the serial monitor problem as well it seems. Though would appreciate if you can explain that.
davidgoth
I don't know if you use BLUNO, it'll influence serial connection. I have never work with BLUNO. Anyway, it could be a timing problem in the GSM library for this board.
I have an idea, you could put LED blinks in each part of sketch to see in which part (how many blinks have happened) sketch stops or fails.
visualxl
Usually it stucks around this area. I don't know why. But if you press the 'RESET' button twice or thrice, it would work.
Code: [Select]
void setupGSM() {
  // connection state
  // Start GSM shield
  while(notConnected) {
    else {
  //sendSMS();
ross12
Hi Guys. I have come across a similar issue where on the serial monitor it says message complete and sent but I still don't get a text on my phone.
I have tried using the SIM card on a phone and it works ok. The code I am using is from the Arduino library "sendSMS..
I used the country's code  +44 before entering my number but still didn't make any difference
I have replaced "GSM gsmAccess;" by "GSM gsmAccess(true); and below is the out put..
SMS Messages Sender
AT%13%
0 6>%13%%10%OK%13%%10%
AT+CGREG?%13%
6 27>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
27 48>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
48 81>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%%13%%10%+SIND: 3%13%%10%
AT+CGREG?%13%
81 102>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
102 7>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%%13%%10%+SIND: 4%13%%10%
AT+CGREG?%13%
7 28>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
28 49>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
49 70>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
70 91>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
91 112>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
112 5>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
5 26>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
26 47>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
47 68>%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
68 89>%13%%10%+CGREG: 0,3%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
102 123>%13%%10%+CGREG: 0,4%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
123 16>%13%%10%+CGREG: 0,4%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
16 37>%13%%10%+CGREG: 0,5%13%%10%%13%%10%OK%13%%10%
AT+IFC=1,1%13%
37 43>%13%%10%OK%13%%10%
AT+CMGF=1%13%
43 49>%13%%10%OK%13%%10%
AT+CLIP=1%13%
49 55>%13%%10%OK%13%%10%
ATE0%13%
55 61>%13%%10%OK%13%%10%
AT+COLP=1%13%
61 67>%13%%10%OK%13%%10%
GSM initialized
Can somebody assist me with this please?
dannable
Just to rule out the obvious, are you using the official Arduino GSM/GPRS shield?
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
ross12
Thanks for your replies guys .
Yeah I am using the official arduino Gsm/GPRS shield..
https://www.sparkfun.com/products/9607
The link above takes you to the shield I am using ..
Thanks
dannable
ross12
Thanks for that. Just out of curiosity what is wrong with the previous  one?
dannable
All the example code provide with the IDE is intended for use with the official shield which uses the Qualtec M10 chip. Some of the code may be specifically for that chip and there is no guarantee that it will work with other chips.
There is a simple example of how to send an sms without using libraries in the link in my signature.
