Topic: Getting elapsed time using ds1307 module (Read 2136 times) previous topic - next topic
syntax_error
Hi everyone,
I'm trying to get the elapsed time with a ds1307. The idea is to press a button and have an LED on for 5 seconds and then turn off. I tried to add 5 seconds to the current time. Compare, and when the current time is over 5 seconds turn off LED. Problem is if I press the button at 58 seconds, add 5 seconds and it goes to 63. Time will never reach 63 so the LED will be on forever. I'm pretty new at this so pardon the noobness. Any help/tips please? Is there a better method of doing this?
Code: [Select]
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
const int button = 2;
const int led = 8;
int buttonState = 0;
time_t current;
time_t duration;
void setup()  {
  pinMode(button, INPUT);
  pinMode(led, OUTPUT);
  while (!Serial) ; // wait until Arduino Serial Monitor opens
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  if(timeStatus()!= timeSet)
     Serial.println("Unable to sync with the RTC");
     Serial.println("RTC has set the system time");
void loop(){
  buttonState = digitalRead(button);
  Serial.print(second());
  Serial.print("\t");
  Serial.print(second(current));
  if(buttonState == HIGH){
    current = now();
    duration = second(current)+5;
    if(duration>60){
      duration = (duration-60);
  Serial.print("\t");
  Serial.print(duration);
  if(duration>second()){
    digitalWrite(led, HIGH);
  }else{
    digitalWrite(led, LOW);
    duration = 0;
CrossRoads
Use 24 hour mode:
Code: [Select]
timeStart = (hours * 60 * 60) + (minutes * 60) + seconds; // second of the day
timeEnd =  (hours * 60 * 60) + (minutes * 60) + seconds; // second of the day
(if (timeEnd - timeStart) >=5){
// do whatever
add days in also if think there will be button pushes at midnight ...
syntax_error
Thank you for your reply! I think I got it to work. I'm going to attach the code in case someone else finds it useful.
Code: [Select]
#include <Time.h>
#include <Wire.h>
const int led = 8;
time_t timeStart;
time_t timeEnd;
void setup()  {
  Serial.print("timeStart");
  Serial.print("\t");
  Serial.print("timeEnd");
  Serial.print("\t");
  Serial.print("\t");
  Serial.print("timeEnd-timeStart");
void loop(){
  timeStart = (hour() * 60 * 60) + (minute() * 60) + second();
  Serial.print(timeStart);
  Serial.print("\t");
    timeEnd = ((hour() * 60 * 60) + (minute() * 60) + second())+5;
  Serial.print(timeEnd);
  Serial.print("\t");
  Serial.print("\t");
  Serial.print(timeEnd-timeStart);
  if ((timeEnd-timeStart) >=5){
  } else{
