Topic: How to Port FreeRTOS in Arduino IDE (Read 7890 times) previous topic - next topic
nikhillife11
Hello All,
Actually I have googled a lot for above help, but couldn't get any specific thing. I have downloaded freeRTOS freeRTOSv702.zip and extracted the same. I copied the folder in libraries of arduino 1.0.5 IDE. Then I even add the library from sketch-> import library.
But still whenever I am trying to compile, I get errors regarding porting. SO do we have any tutorials to port the RTOS or can specific any particular things. I am using ARDUINO UNO for my learning purpose
Also It will be of great help, if anyone can provide with a sample example to confirm complilation
Regards
Nikhil
Riva
I just went to the link in this thread. Downloaded FreeRTOS20130714.zip. Extracted the FreeRTOS_AVR folder to Projects/libraries and compiled the example frBlink.ino sketch without problem.
What libraries are you trying to use and what are the errors you get?
Don't PM me for help as I will ignore it.
nikhillife11
Hello Riva
By project folder do you mean, arduino-1.0.5/libraries/. So i downloaded the zip file you have said. I will copy the FreeRTOS folder in libraries.
Also can you share the example file pl.
Regards
Nikhil
Riva
No not there, look at this guide on installing libraries.
The example along with several others is include in the FreeRTOS library folder you will copy.
nikhillife11
Hello Ravi,
Actually I tried the things as the links said. But still facing some error. I have attach the logs. I see that it is not able to get FreeRTOS.h files. Not able to find why. Hope you can help me
ERROR IS AS FOLLOWS
D:\arduino-1.0.5\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -ID:\arduino-1.0.5\arduino-1.0.5\hardware\arduino\cores\arduino -ID:\arduino-1.0.5\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\Nikhil\AppData\Local\Temp\build6734853460650207127.tmp\frBlinkPrint.cpp -o C:\Users\Nikhil\AppData\Local\Temp\build6734853460650207127.tmp\frBlinkPrint.cpp.o
frBlinkPrint.ino:3:26: warning: FreeRTOS_AVR.h: No such file or directory
frBlinkPrint:10: error: 'xTaskHandle' does not name a type
frBlinkPrint.ino: In function 'void vLEDFlashTask(void*)':
frBlinkPrint:23: error: 'configTICK_RATE_HZ' was not declared in this scope
frBlinkPrint:23: error: 'vTaskDelay' was not declared in this scope
frBlinkPrint.ino: In function 'void vPrintTask(void*)':
frBlinkPrint:36: error: 'configTICK_RATE_HZ' was not declared in this scope
frBlinkPrint:36: error: 'vTaskDelay' was not declared in this scope
frBlinkPrint.ino:39: warning: only initialized variables can be placed into program memory area
frBlinkPrint.ino:43: warning: only initialized variables can be placed into program memory area
frBlinkPrint:44: error: 'blink' was not declared in this scope
frBlinkPrint:44: error: 'uxTaskGetStackHighWaterMark' was not declared in this scope
frBlinkPrint:48: error: 'freeHeap' was not declared in this scope
frBlinkPrint.ino: In function 'void setup()':
frBlinkPrint:62: error: expected primary-expression before 'signed'
frBlinkPrint:62: error: expected `)' before 'signed'
frBlinkPrint:70: error: expected primary-expression before 'signed'
frBlinkPrint:70: error: expected `)' before 'signed'
frBlinkPrint:77: error: 'vTaskStartScheduler' was not declared in this scope
frBlinkPrint.ino:80: warning: only initialized variables can be placed into program memory area
Thanks and Regards
Nikhil
gallegojm
Hi
As we are in the forum dedicated to Due, I assume you are trying to use FreeRTOS on a Due.
So you have to use use the FreeRTOS_ARM library. Not the FreeRTOS_AVR one as it seems you are doing:
Quote
Hope this could help you to solve your problem
nikhillife11
Hello Galle,
I am using arduino uno boards. So should i use ARM header file or Avr header file
Regards
Nikhil
Riva
It means we are in the wrong forum (I came here from unread posts and did not notice) and you should be using AVR for UNO
Coding Badly
Thread moved to a more appropriate section.
Riva
