Topic: Problem uploading to board (Read 5771 times) previous topic - next topic
tgriff777
I was wondering why my Arduino board all of a sudden stopped uploading. I can't seem to upload any programs I make on to it. It results in this error:
avrdude: stk500_recv(): programmer not responding
The thing is, it was working like a charm a few days ago and then this happens. Let me know what could be causing this problem.
AWOL
Feel free to provide details.
OuterPlexis
I am having the same problem yet this is with a newly purchased board, and with IDE version 1.5.6-rc2 (latest one downloaded). Sometimes when I open the Serial Monitor and quickly there-after try to upload it works, but it's very iffy.
Here's a copy of exactly what I'm getting:
Sketch uses 18,138 bytes (63%) of program storage space. Maximum is 28,672 bytes.
Global variables use 520 bytes (20%) of dynamic memory, leaving 2,040 bytes for local variables. Maximum is 2,560 bytes.
Forcing reset using 1200bps open/close on port /dev/tty.usbmodem1421
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.Bluetooth-Modem, /dev/cu.SarelsiPhone4S-Wireless, /dev/cu.usbmodem1421, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Modem, /dev/tty.SarelsiPhone4S-Wireless, /dev/tty.usbmodem1421, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.Bluetooth-Modem, /dev/cu.SarelsiPhone4S-Wireless, /dev/cu.usbmodem1421, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Modem, /dev/tty.SarelsiPhone4S-Wireless, /dev/tty.usbmodem1421, } => {}
Uploading using selected port: /dev/tty.usbmodem1421
/Applications/ARDUINO/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/ARDUINO/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P/dev/tty.usbmodem1421 -b57600 -D -Uflash:w:/var/folders/sd/dzpfsctx5dlfdmt84z53xm3r0000gn/T/build4326096569440213265.tmp/Bridge.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/ARDUINO/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/sarel/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbmodem1421
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: ser_recv(): programmer is not responding
avrdude: butterfly_recv(): programmer is not responding
processing.app.debug.RunnerException
   at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:125)
   at processing.app.Sketch.upload(Sketch.java:1719)
   at processing.app.Sketch.exportApplet(Sketch.java:1625)
   at processing.app.Sketch.exportApplet(Sketch.java:1597)
   at processing.app.Editor$DefaultExportHandler.run(Editor.java:2397)
   at java.lang.Thread.run(Thread.java:695)
Caused by: processing.app.debug.RunnerException: Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
   at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:111)
   at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:123)
   ... 5 more
At this point it just hands...
... This might be a problem with avrdude I think?
OuterPlexis
Hmmm... I think this might be a problem with 1.5.6-rc2. I just removed it completely from my mac, and downloaded and installed 1.5.5-BETA and now I can upload fine.
wvdheiden
Hi
I have the same problem. I'm using the Arduino Software Version 1.5.8 (Java 7) on a Mac with MAc OS 10.9.5.
I have an Arduino Uno connected using USB (changed the cable 3 times) but there is no port with USB in the name appearing, only bluetooth ports.
Uploading does not work and gives errors:
Arduino: 1.5.8 (Mac OS X), Board: "Arduino Uno"
Build options changed, rebuilding all
compile::: OK
avrdude: Version 6.0.1, compiled on Apr  3 2014 at 22:00:33
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/wvdheiden/.avrduderc"
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "/dev/tty.usbmodem1421": No such file or directory
ioctl("TIOCMGET"): Inappropriate ioctl for device
avrdude done.  Thank you.
I can find the problem here. Any suggestions?
Walter
