Hello guys,
I already try the code and it works like a charm. I was trying to modify it because I want to start and end the acquisition of data remotely. I bought a cheap RF transmitter and receiver (https://www.sparkfun.com/products/10532 and https://www.sparkfun.com/products/retired/8946) and downloaded the virtualwire library (VirtualWire: VirtualWire library for Arduino and other boards). To start the acquisition I modified the code like this:
void setup(void) {
if (ERROR_LED_PIN >= 0) {
pinMode(ERROR_LED_PIN, OUTPUT);
vw_setup(2000); // Bits per sec
vw_set_rx_pin(8) ;
vw_rx_start(); // Start the receiver
// Read the first sample pin to init the ADC.
analogRead(PIN_LIST[0]);
Serial.print(F("FreeRam: "));
Serial.println(FreeRam());
// initialize file system.
if (!sd.begin(SD_CS_PIN, SPI_FULL_SPEED)) {
sd.initErrorPrint();
fatalBlink();
void loop(void) {
Serial.println();
Serial.println(F("type:"));
Serial.println(F("c - convert file to CSV"));
Serial.println(F("d - dump data to Serial"));
Serial.println(F("e - overrun error details"));
Serial.println(F("r - record ADC data"));
while(!vw_get_message(message, &msgLength)) {}
digitalWrite(ERROR_LED_PIN, LOW);
if (message[0] == 'c')
binaryToCsv();
else if (message[0] == 'd')
dumpData();
else if (message[0] == 'e')
checkOverrun();
else if (message[0] == 'r')
logData();
Serial.println(F("Invalid entry"));
So when i send the letter r from my other arduino the one with the sd card starts recording. The problem is when I try to stop it. To do so I modified the logdata function:
if (vw_get_message(message, &msgLength)) {
// stop ISR calls
adcStop();
if (isrBuf != 0 && isrBuf->count >= PIN_COUNT) {
// Truncate to last complete sample.
isrBuf->count = PIN_COUNT*(isrBuf->count/PIN_COUNT);
// put buffer in full queue
fullQueue[fullHead] = isrBuf;
fullHead = queueNext(fullHead);
isrBuf = 0;
if (fullHead == fullTail) break;
But the former does not work. I read in the virtualwire documentation that it uses timer1 and I think that is why my code is not working but I don't know how to fix it.
Any advice?
Thanks in advance to you all
