Topic: Recommended battery power source for NEMA 17 bipolar stepper? (Read 11571 times) previous topic - next topic
duncan916
Hi. Can someone recommend a power supply to use for my stepper motor? I tried to test it with a 9V battery and I was told that was foolish. I would like to run it off several AA or C batteries, or a rechargeable lithium ion pack.
I am using a NEMA17 Bipolar Stepper Motor, it's rated voltage is 2V-36V, it's rated current is 1.2A
My driver is the DRV8834 Low-Voltage Stepper Motor Driver Carrier which operates at 2.5-10.8 V and can deliver up to approximately 1.5 A per phase continuously without a heat sink or forced air flow (up to 2 A peak).
Ultimately I want to power this motor for 12-24+ hours on one charge or set of batteries, but it will only be doing one step every 1-15 minutes, so it won't be running at full speed the whole time. Right now I'd just like to get it running so I can start writing my program and testing it though.
CrossRoads
Get a wallwart for now.
http://www.mpja.com/5-Volt-DC-Plug-Power-Supply-4A-Regulated/productinfo/18520%20PS/
Replace with a 2-cell (7.4V) high amp-hour LiPo later on when you've determined your actual needs.
duncan916
So I need to hook the wallwart up to a 2A resistor to use it? I don't want to fry my driver...
Also, I should mention I don't want to spend $200 on the battery haha
CrossRoads
Google LiPo batteries, they are common & inexpensive, many radio control car places carry them.
You said the motor and driver are both rated for >7.4V; no resistor needed.
duncan916
The wallwart says it provides 7.4V at 5 amps though, the driver is rated for 2A, do I need to protect it? I don't want to fry my driver board
Robin2
A stepper motor draws full current all the time even when stationary. If it has to be battery powered I suggest a large lead-acid battery - perhaps a used car starter battery if you can use 12volts.
That stepper driver can only take up to 10.8 volts and that will limit the performance of the motor. If you could get a driver that can take up to 30volts you could use a 12v or 24v battery.
Quote
I have no idea where you got this concept from. I suggest some study of the difference between amps and volts.
You can only fry something if you have too many volts AND there is a big enough supply of current. If the voltage is correct it doesn't matter whether there are thousands of Amps available, the device will just take what it needs. If you have the correct voltage and not enough amps you may damage the power supply. The best option is the correct voltage and a surplus of amps.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
CrossRoads
The motor will only draw the current when the controller lets it have & low outputs acros a coil - and the current will be limited by all the parts in series: the source  voltage, the motor impedance, and the voltage drop across the driver.
Say the motor coil was connected to 5V on one side and the driver connected the other side to Gnd and had a 1.1V drop on its transistors doing that.
Then the current would be (5V - 1.1V)/motor winding resistance = amps if left on long term.
Steppers work by getting pulses of current thru them, so they have an AC component of resistance called impedance. So the current will be different if you could measure it during pulses than if you use a multimeter and measure the coil winding statically (unpowered) and calculate as above.
CrossRoads
duncan916
Can you recommend somewhere I can buy the female part that I can use to plug that power supply into my protyping board? I don't know what to look for
duncan916
Also if you could recommend a part that I could plug that battery into that I can put on my protyping board that would be great.
duncan916
I just ordered this part here: http://www.allelectronics.com/make-a-store/item/dcj-1/2.1mm-dc-power-jack/1.html?extra=a%3A2%3A{i%3A0%3Bs%3A40%3A%2203823345592a403b2f4a37a59384e7ab28f02be1%22%3Bi%3A1%3BN%3B}
Hopefully it's the right one?
Also, could you suggest a similar plug that I could use to link the battery you mentioned to my breadboard?
CrossRoads
Drill a hole, screw this onto your board - or onto your enclosure wall.
http://www.mpja.com/55mm-OD21mm-ID-Chassis-Power-Connector/productinfo/18549%20PL
duncan916
Theoretically if I run the 1.2A stepper at 5v that's 6 watts,
which means this battery: http://www.ebay.com/itm/NEW-Duratrax-Onyx-LiPo-2S-7-4V-2000mAh-25C-Traxxas-DTXC1837-NIB-/390785819028?_trksid=p2054897.l4275
Would give me at least 2.5 hours of run time, correct?
I need to find a battery that can give me 25 hours, or at least 12... that's also cheap... $25 is ideal. Anything over $50 I probably cannot consider.
CrossRoads
The stepper will be moving full speed the whole time?
Then yes, 1.2A * 25 hrs = 30AH battery = 30,000mAH
Maybe this?
http://www.batts.com/duracell-mn918-6v-30ah-alkaline-lantern-battery.html
Puts you into big battery league. Are you sure you need that much power?
Robin2
Cheapest solution (which I suggested earlier) is to get a stepper driver board that can use a higher voltage and then get a used 12v car battery - probably free or cheap.
Always assume that the amp-hour rating written on battery stickers is 2 times higher than the real usable value.
...R
