Topic: TTL BCD-7 Segment display driver IC, problem (Read 5541 times) previous topic - next topic
lost_and_confused
Folks,
I am building a project and I want 2 x 7 Segment displays.
To minimise pin usage, I thought I would use a BCD-7 Segment display driver.
I want to use 5 volts, so I looked in my TTL cookbook.  7447.  Ok, but it is for common ANODE displays.
It puts the outputs LOW to activate the segment.  Ok.   It also boasts that it can drive nixi and other kinds of displays.
If I want to use LED it is said to use 330 ohm resistors.
But looking at the 7 Segment displays they are common CATHODE!
So it won't exactly work.
How else can I do this?
Or what am I missing?
Paul__B
You can multiplex it with nine wires (including the decimal).  Use two NPN transistors to drive the common cathodes, one is controlled from a port line via a 1k resistor, its collector is connected to the base of the second via two diodes in series with the midpoint of the two diodes, the anode of each, pulled up by another 1k resistor to 5V.
runaway_pancake
Gosh - if only there were a way that electronics concepts could be laid out graphically.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Paul__B
Yes, if only.
(I was hoping someone with that skill and enthusiasm might do it with lightning speed, as I couldn't think of how to just before bedtime.)
lost_and_confused
Chuckle.
Yeah, I am trying to get my head around what you said.
Sorry, but I am a bit confused.
The brightness will be adjusted by using a PWM pin as the common.....  what ever.
Could I use a CMOS BCD-7 segment chip at 5V reliably?
JChristensen
What's on the next page, right after the 7447?
runaway_pancake
Yes, if only.
Pencil, paper; take a picture; attach it.
Arduous.
lost_and_confused
(BIG BLUSH!)
My TTL cookbook is a 1982 version.
So a 7448 is not listed.
Thanks.
runaway_pancake
Get a 4511 (CD4511, et al.) or a different display.
JChristensen
Haha, is that Don Lancaster's TTL Cookbook? My copy (1976) doesn't seem to have it either. But my copy of TI's TTL Databook (1973) does.
7448 might be getting hard to find, but there is a 74248 or something similar, don't know if availability might be any better for that.
CrossRoads
MAX7219, drives up to 8 common cathode displays with SCK, MOSI, SS from Ardunino.
Or LED library and any pins for bit-banged interface.
Or 2 cd4AC164 shift registers. Do the value o- segment mapping in software, just an array lookup:
SPI.transfer(fontArray[numberToDisplay[0]]);
SPI.transfer(fontArray[numberToDisplay[1]]);
or
shiftOut (dataPin, ClockPin, MSBFIRST, fontArray[numberToDisplay[0]]);
shiftOut (dataPin, ClockPin, MSBFIRST, fontArray[numberToDisplay[1]]);
lost_and_confused
Thanks folks.
Given the 7448 (or 74LS48) I found at Jaycar.  Local electronics shop.
So now I have to do a bit or thinking about the sketch and "board" layout.
