Arduino Forum
Using Arduino
Displays
(Moderator:
PerryBebbington
Nokia 5110 LCD Not working at all.
Pages:
[1]
Topic: Nokia 5110 LCD Not working at all.
(Read 7558 times)
previous topic
next topic
yuh25
Guest
Mar 31, 2014, 03:25 pm
Last Edit
: Mar 31, 2014, 03:26 pm by yuh25
Reason
: 1
Hi, I got a Nokia 5110 LCD display today and I've been trying to get the thing to work all day. The closest thing I got to displaying anything at all was when I remove the Vcc pin and it just displays line very quickly.
I've used the sketch here:
http://playground.arduino.cc/Code/PCD8544
Aswell as any other sketch that I could find.
Thanks.
Nick_Pyner
[add]
Please don't PM me. Doing so deprives others of my pearls of wisdom, and you might be depriving yourself of even brighter pearls from them.
Re: Nokia 5110 LCD Not working at all.
#1
Mar 31, 2014, 04:40 pm
The picture isn't too flash, but it looks like you are running it off 5v, it should be 3.3v. There might be other power issues. You have no limiting resistor for the LEDs. Try running it with the LED wire disconnected
yuh25
Guest
#2
Apr 01, 2014, 03:11 am
Last Edit
: Apr 01, 2014, 03:14 am by yuh25
Reason
: 1
Sorry, this is how I have it wired up:
http://imgur.com/iMbCE8o
Pins on the display from left to right: RST , CE , DC , CLK , Vcc , BL , Gnd.
I've tried with 10k resistors on the data inputs and LED.
Nick_Pyner
[add]
#3
Apr 01, 2014, 03:21 am
Quote from: yuh25 on Apr 01, 2014, 03:11 am
I bet you didn't, but it does imply you are running it off 3.3v. Try disconnecting the LED.
yuh25
Guest
#4
Apr 01, 2014, 03:34 am
I've tried.
The only thing I can think that would be wrong is its a dodgy screen or the pins are labeled wrong.
Nick_Pyner
[add]
#5
Apr 01, 2014, 04:25 am
These things are surplus but the fact that you got a fleeting result suggests it is OK. There are variations in the wiring. I got mine going only by accident. Mine is the same order, but the LED is wired to ground. This is one reason why I said disconnect it. You might try grounding it through a 1k resistor.
Your wiring order seems OK.
yuh25
Guest
#6
Apr 01, 2014, 05:14 am
Didn't appear to do anything with the resistor. =\
Nick_Pyner
[add]
#7
Apr 01, 2014, 05:57 am
OK, I have run out of ideas. If you have it wired like the diagram, it will never work - hence my comment. If it is still wired like the picture, it should. Running the LED with no resistor isn't a good idea, but I have done it and nothing fried.
yuh25
Guest
#8
Apr 01, 2014, 06:32 am
Rightio, thanks anyway. I'm just gonna RMA it. =\
polypagan
[add]
#9
Apr 01, 2014, 08:20 pm
I struggled to get mine going too... Almost gave up.
My problem turned out to be the contrast setting.
The fact that you see something on the display as it powers down suggests you have it connected okay (enough).
Arrange to vary the contrast setting during init. Value can range from 0 to 127 (always OR'd with 0x80 before sending).
No need to try all values, just walk through the range.
Mine now works with many different libraries.
Good luck!
There are 10 kinds of people in the world, those who understand binary, and those who don't.
Nick_Pyner
[add]
#10
Apr 02, 2014, 12:02 am
Contrast. Yes. I think that could be the answer, even though I never had the situation where there was nothing. I believe Stuart Little's tutorial had a bit about that. Also perhaps here
http://ianlangelectronic.webeden.co.uk/#/lcd-module-0/4569058582
I believe the contrast requirement varies according to what is on the screen and, consequently, striving for good graphics contrast is not worth the effort. I believe I modified the Philips pcd8544 library with Lewis's contrast setting.
yuh25
Guest
#11
Apr 02, 2014, 04:44 am
Found the problem. Changing the contrast values seemed to do nothing, so I checked the datasheet and tried changing the values in the init and changed the 'LCD bias mode' to 0x17.
Nick_Pyner
[add]
#12
Apr 02, 2014, 05:13 am
OK. It looks like you have made a significant contribution to the vagaries of the 5110.
I think I started on 0x13 but I now use 0x14 for all displays. Once done, I have never changed it, and I have never had your problem.
Your original code was 0x14 too, so it never dawned on me that the same setting could cause such a difference between different examples.
Trebbie
[add]
#13
Jun 23, 2019, 01:47 pm
I found this old question.
It is the same problem by me. I need to set the bias mode to 0x14.
With using:
[Select]
LcdWrite(LCD_C, 0x14 ); // LCD bias mode 1:48.
my device work.
But I want to use the Adafruit_PCD8544 libary.
How can I change here the bias-mode?
Nick_Pyner
[add]
#14
Jun 23, 2019, 05:00 pm
Last Edit
: Jun 23, 2019, 05:01 pm by Nick_Pyner
I believe this conversation is all about using the 5110 without a library. Since then, I have been using the
Philips
PCD8544 library and have never needed to make any changes. This may be because I have always used it for plain text with strokes 1 pixel wide.
Pages:
[1]
