Topic: A/D Arduino converter (Read 630 times) previous topic - next topic
zaciatok
Hello,
I would like to ask you very kindly about 10bit arduino converter. If I am using 2V as reference voltage then to calculate its resolution I can apply the following formula Vref/(2^N-1) or Vref/(2^N) ??? which one is correct??? . Moreover, If the converter give 512, to calculate the corresponding voltage value I can use this formula 512*(Vref/1023) and if it is giving 256 then 256*(Vref/1023) and so on ???? in other words is it correct to use 1023 or 1024 for 10 bit converter???
Thank you in advance for your response.
AWOL
You already asked this question here
