Topic: Arduino Mini schematic incorrect? (Read 2571 times) previous topic - next topic
greyskale
Perhaps I'm just imagining things, but I was looking at the Mini schematics last night and noticed that the chip is listed as an ATMEGA8 when it should be ATMEGA168 no? Also, the pictures of the board show all of 4 components total while the schematic shows 10. Just wondering regarding this because it's a little more unusual to have smt parts on both sides of the board.
I am working on a purpose specific Arduino board, so I want to make sure I can avoid including any unnecessary parts.
admin
hi
a few notes
Atmega8 and 168 are pin compatible so it's all the same
the schematic is the bare minimum already but it's correct (it's the one used for production)
there are parts on the bottom side. it's quite common when you dont have that much space
making a custom smd board requires quite a bit of experience, wouldn't it be simpler to get a mini put your stuff on another board connected to it...
massimo
greyskale
I'll be picking up a mini for dev work, but in the end I want a all in one board (it'll have more components to suit it's use).
I don't have any problem designing smt boards, but the software I use won't allow smt parts on the back of the board :(
thanks for the info though
admin
wow even eagle free version lets you do that
what software are u using?
BTW when you have made your board you should document it on the playground
greyskale
#4
Dec 08, 2006, 08:11 pm Last Edit: Dec 08, 2006, 08:22 pm by greyskale Reason: 1
I'm using Osmand... I want to use Eagle, but I'm on a mac and I seem to have issues with the installer.
:edit: it won't let me install X11, telling me I already have a newer version installed (which I don't) so I can do anyting with it >:(
Daniel
#5
Dec 08, 2006, 08:21 pm Last Edit: Dec 08, 2006, 08:21 pm by Daniel Reason: 1
try to get Eagle going, it is about twenty times better than Osmond. You need X11 to run it on a mac; I've installed Eagle on four macs with no problem...
greyskale
do you have any advice regarding installation? when I try to install X11 I get the message: "You can not install X11 on this volume. Newer Software already exists on your computer"
This is untrue... I don't have X11 on my machine... hense the need for installation ;)
Daniel
#8
Dec 09, 2006, 02:39 am Last Edit: Dec 09, 2006, 02:40 am by Daniel Reason: 1
It could be a lot of different things causing that, and I'm no X11 expert... did you try trashing any preference file(s) for X11?
a quick google search comes up with this:
http://lists.apple.com/archives/x11-users/2006/Oct/msg00020.html
D
greyskale
I think I know the issue now... I've been trying to install the version on apples site... this is an older version for 10.3. I'll try to use the installer on my 10.4 disks when I get home tonight and see if that works.
xSmurf
You might also want to have a look at the installation receipt from X11 in /Library/Receipts/.
DesInstaller is a nice little tool to deal with these (it also removes the associated files).
Also keep in mind that although you can start eagle from the Terminal.app (not xTerm) you need to have X11 started already for this to work!
If you still have problems, you could try installating Eagle from a package distribution (iirc Darwinports has it listed).
Hope this helps!
