Topic: Connecting an Arduino+GSM shield to a small device that receives simple commands (Read 979 times) previous topic - next topic
clod85
I'd like to have some of your opinions !
I have a device connected to Arduino that receives small simple remote commands (00, 01, 10, 00) even with an high frequency.
I'd  use Arduino as a web server through a GPRS connection, using the Bluevia SIM card found in the GSM shield box. The server listens continuosly for new commands, reacting when it receives them. I can't use Ethernet nor wi-fi connection.
I suppose to build a small http page with a smart interface that would allow me to send the above written commands through a http protocol.
I read projectswhere sensor data is sent to specific database but I've never read descriptions of project like mine.
Do you think is it possible ? Do you have any better ideas?
Thank you very much !!! :)
BhanuTejaJ
Personally, what I understood is, you what to SEND data (commands) received by your Arduino to a Server. Where your Server can responds.
Am I correct ??,.... If so, It is possible.
clod85
Thank you very much for your reply!
Is my english not clear or the descriptions of the project ?
I try to explain better; I want to turn Arduino with a GSM shield to a web server listening for the commands sent through a simple interface built on an Internet page. I have to send 4 different commands. The commands cheanges the values of the digital pins of Arduino. Arduino should be able to receive commands with an high frequency. I suppose to have a very low latency.
I've read that send sensor data to a database is feasible; Would Arduino be able to receive several commands through a GPRS connection ?
still thank you for helping me !
BhanuTejaJ
Sorry, Actually Title of the Project was bit confusing : smiley-slim: .
Did you tried examples in the Arduino-IDE(Arduino1.0.5,Software) ?? , they are two examples of WEB-Server and WEB-Clint.
Try them once. I think your doubts will be solved.
check this link: http://arduino.cc/en/Tutorial/GSMExamplesWebServer
