Topic: Read CSV or TXT from SD card into string or array (Read 38778 times) previous topic - next topic
Duke1215
I am working on an system and need to read values on an sd card. The txt or csv will have multiple lines with 2 rows of values. What I would like to achieve is for the arduino to open the sd file, take line one, split it into its two values. val1 and val2. It will then compare the values to what a sensor reads. If they match, it will stop searching the txt file. If the values don't match, it will read and compare the values from the next line in the txt file. I am very new to programming and think the values would either be a string or array. Please help! Thanks
CatweazleNZ
You can read SD card files line-by-line if this helps:
Code: [Select]
String l_line = "";
//open the file here
while (l_SDFile.available() != 0) {
    //A inconsistent line length may lead to heap memory fragmentation
    l_line = l_SDFile.readStringUntil('\n');
    if (l_line == "") //no blank lines are anticipated
   //parse l_line here
//close the file here
Cheers
Catweazle NZ
CatweazleNZ
Hi
This more substantial procedure loads a backup file with multiple record types into memory arrays:
Code: [Select]
boolean LoadRecentClimateBackupFile(){
 const byte c_proc_num = 31;
 Push(c_proc_num);
 //After Climate Arrays have been initialised (nulled)
 //After call to CalcNextClimateCheck()
  30MN Left Temp 22 22 22 23 23 23 23 23 24 24 24 24
  30MN Left Humidity 62 62 62 60 60 60 60 59 59 59 59 59
  DAY Left Temp Max NULL NULL NULL NULL NULL 24 24
  DAY Left Temp Min NULL NULL NULL NULL NULL 22 20
  DAY Left Humidity Max NULL NULL NULL NULL NULL 67 62
  DAY Left Humidity Min NULL NULL NULL NULL NULL 58 59
  AIRPUMP 22 22 22 23 23 23 23 23 24 24 24 24
 if (!G_SDCardOK) {
   Pop(c_proc_num);
   return false;
 SPIDeviceSelect(DC_SDCardSSPin);
 int l_yyyy, l_mm, l_dd, l_hh, l_mn = 0; //l_ss
 String l_SD_filename = "";
 long l_PeriodTime   = 0;
 int  l_PeriodOffset = 0;
 boolean l_SD_file_found = false;
 //Look back up to 12 climate periods for the most recent backup file
 for (byte l_count = 1; l_count <= 12 ; l_count++) {
   l_PeriodTime = Date() + G_NextClimateUpdateTime - long(100000 * l_count / G_Periods_Per_Day) + 1; //Fourth backup ago, fraction adjusted
   DateDecode(l_PeriodTime, &l_dd, &l_mm, &l_yyyy);
   TimeDecode(l_PeriodTime, &l_hh, &l_mn);
   //l_SD_filename = String(ZeroFill(l_mm,2) + ZeroFill(l_dd,2) + ZeroFill(l_hh,2) + ZeroFill(l_mn,2) + ".TXT");
   String l_directory = String(EPSR(E_BACKUPSsl_2217) + ZeroFill(l_yyyy,4) + "/" + ZeroFill(l_mm,2) + "/" + ZeroFill(l_dd,2) );
   SD.mkdir(&l_directory[0]);
   l_SD_filename = String(l_directory + "/" + ZeroFill(l_mm,2) + ZeroFill(l_dd,2) + ZeroFill(l_hh,2) + ZeroFill(l_mn,2) + ".txt");
   //BACKUPS/2013/11/10/11101800.txt
   if (SD.exists(&l_SD_filename[0])) {
     l_SD_file_found = true;
   l_PeriodOffset += 1;
 CheckRAM();
 if (!l_SD_file_found) {
   SPIDeviceSelect(DC_EthernetSSPin);
   Pop(c_proc_num);
   return false;
 int l_DayOffset = 0;
 //If the date of the backup file we will load is yesterday
 //we need to offset (7) DAY climate data by one day.
 if (l_PeriodTime < Date()) //Date() is midnight 12:00am - the start of today
   l_DayOffset = 1;
 //We have found the most recent backup and have offsets for missed data
 //BACKUPS/2013/11/10/11101800.TXT
 //Serial.println(l_SD_filename);
 File l_SD_file = SD.open(&l_SD_filename[0],FILE_READ);
 CheckRAM();
 if (! l_SD_file) {
   ActivityWrite(String(EPSR(E_Could_not_open_file__1345) + l_SD_filename)); //Should not happen - we know it exists
   Pop(c_proc_num);
   return false;
 int* l_row; //An int array pointer
 String l_reqd_stattype = DetermineStatType(G_Periods_Per_Day);
 while (l_SD_file.available() != 0) {
   //Hopefully the relatively small size of the files and consistent
   //line length will minimise any String memory fragmentation
   String l_line = l_SD_file.readStringUntil('\n');
   //Serial.println(l_line);
   //30MN Right Humidity 60 60 60 60 60 59 58 58 58 58 58 58
   //DAY Left Temp Max NULL NULL NULL NULL NULL 24 24
   //AIRPUMP 22 22 22 23 23 23 23 23 24 24 24 24
   int l_posn = 0;
   String l_stattype = ENDF2(l_line,l_posn,'\t');
   if (l_stattype == "AIRPUMP") {
     int l_index1  = DC_ClimatePeriodCount - 1;
     int l_Offset = l_PeriodOffset;
     for (int l_count2 = 1; l_count2 <= DC_ClimatePeriodCount; l_count2++) { //twelve
       String l_value = ENDF2(l_line,l_posn,'\t');
       if (l_value == "") //If index not back to zero we have gaps in the recovered data
                          //because we could not load the most recent backup file.
         break; //we have finished
       if (l_Offset == 0) { //We can load this value
         if (l_value != EPSR(E_NULL_2006))
           G_AirPumpModes[l_index1] = l_value.toInt();
           G_AirPumpModes[l_index1] = 0;
         l_index1--;
       else //We discard end value(s) because we only have an old backup (not the most recent)
         l_Offset--; //By skipping index values we will leave null gaps in the data in the lower array index values
       if (l_index1 < 0)
     } //for each array element
   else {
     String l_sensor   = ENDF2(l_line,l_posn,'\t');
     String l_stat     = ENDF2(l_line,l_posn,'\t');
     int l_sensor_index = 0; //scoped for later use
     boolean l_sensor_found = false;
     for (l_sensor_index = 0; l_sensor_index < DC_SensorCountTemp; l_sensor_index++) {
       if (C_SensorList[l_sensor_index] == l_sensor) {
         l_sensor_found = true;
     } //find the sensor
     if (l_sensor_found) { //skip removed sensors
       if (l_reqd_stattype == l_stattype) {
         //This is a periodic data set
         int l_ValueOffset = 0;
         if (l_stat == EPSR(E_Temp_2398)) {
           l_row = G_ArrayTemp[l_sensor_index].TempPeriodic;
           l_ValueOffset = DC_Temp_UpShift;
         else if (l_sensor_index < DC_SensorCountHum) //Humidity
           l_row = G_ArrayHum[l_sensor_index].HumPeriodic;
         if ((l_stat == EPSR(E_Temp_2398)) || (l_sensor_index < DC_SensorCountHum)) {
                 l_row[l_index1] = int((StringToDouble(l_value) + l_ValueOffset) * 10);
                 l_row[l_index1] = 0;
               l_index1--;
             if (l_index1 < 0)
         } //skip humidity statistics not now required
       } //periodic stat type
       else if (l_stattype == "DAY") {
         String l_sub_stat = ENDF2(l_line,l_posn,'\t'); //Min or Max
         //This is a day min/max data set
         l_row = NULL;
         if ((l_stat == EPSR(E_Temp_2398)) && (l_sub_stat == "Max")) {
           l_row = G_ArrayTemp[l_sensor_index].TempMax;
         else if ((l_stat == EPSR(E_Temp_2398)) && (l_sub_stat == "Min")) {
           l_row = G_ArrayTemp[l_sensor_index].TempMin;
         else if ((l_stat == EPSR(E_Humidity_1184)) && (l_sub_stat == "Max")) {
             l_row = G_ArrayHum[l_sensor_index].HumMax;
         else { //if ((l_stat == "Humidity") && (l_sub_stat == "Min"))
             l_row = G_ArrayHum[l_sensor_index].HumMin;
           int l_index2 = DC_WeekDayCount - 1;
           int l_Offset = l_DayOffset;
           for (int l_count3 = 1; l_count3 <= DC_WeekDayCount; l_count3++) { //7 days
             if (l_value == "")
                 l_row[l_index2] = int((StringToDouble(l_value) + l_ValueOffset) * 10);
                 l_row[l_index2] = 0;
               l_index2--;
               l_Offset--;
             if (l_index2 < 0)
           } //Load each day of the week
       } //Determine what type of statistic (Periodic or DAY)
     } //Skip removed sensors
   } //Process AIRPUMP data differently
 } //EOF
 CheckRAM();
 l_SD_file.close();
 Pop(c_proc_num);
 return true;
} //proc
Catweazle NZ
CatweazleNZ
You will also need this to parse your input lines if you are using a delimiter between multiple fields/values on each line:
Code: [Select]
String ENDF2(String &p_line, int &p_start, char p_delimiter) {
  const byte c_proc_num = 27;
  Push(c_proc_num);
//Extract fields from a line one at a time based on a delimiter.
//Because the line remains intact we dont fragment heap memory
//p_start would normally start as 0
//p_start increments as we more along the line
//We return p_start = -1 with the last field
  //If we have already parsed the whole line then return null
  if (p_start == -1) {
Pop(c_proc_num);
return "";
  CheckRAM();
  int l_start = p_start;
  int l_index = p_line.indexOf(p_delimiter,l_start);
  if (l_index == -1) { //last field of the data line
p_start = l_index;
Pop(c_proc_num);
return p_line.substring(l_start);
  else { //take the next field off the data line
p_start = l_index + 1;
Pop(c_proc_num);
return p_line.substring(l_start,l_index); //Include, Exclude
  //Pop(c_proc_num);
Ignore calls to Push, Pop and CheckRAM.
Cheers
Catweazle NZ
fat16lib
Here is a simple sketch that reads a CSV file with two numbers on each line.  It doesn't use the dangerous String class.
Code: [Select]
#include <SD.h>
File file;
bool readLine(File &f, char* line, size_t maxLen) {
  for (size_t n = 0; n < maxLen; n++) {
    int c = f.read();
    if ( c < 0 && n == 0) return false;  // EOF
    if (c < 0 || c == '\n') {
      line[n] = 0;
      return true;
    line[n] = c;
  return false; // line too long
bool readVals(long* v1, long* v2) {
  char line[40], *ptr, *str;
  if (!readLine(file, line, sizeof(line))) {
    return false;  // EOF or too long
  *v1 = strtol(line, &ptr, 10);
  if (ptr == line) return false;  // bad number if equal
  while (*ptr) {
    if (*ptr++ == ',') break;
  *v2 = strtol(ptr, &str, 10);
  return str != ptr;  // true if number found
void setup(){
  long x, y;
  if (!SD.begin(SS)) {
    Serial.println("begin error");
    return;
  file = SD.open("TEST.CSV", FILE_READ);
  if (!file) {
    Serial.println("open error");
    return;
  while (readVals(&x, &y)) {
    Serial.print("x: ");
    Serial.println(x);
    Serial.print("y: ");
    Serial.println(y);
  Serial.println("Done");
void loop() {}
Reading this "TEST.CSV" file.
Quote
1,2
34,56
987,-765
1234,-5678
Results in this output
Quote
x: 1
y: 2
x: 34
y: 56
x: 987
y: -765
x: 1234
y: -5678
Done
orthho
Hi fat16lib..i want to ask some question the same that i've posted in other topics
http://forum.arduino.cc/index.php?topic=127711.15 (i didn't mean to flood or something)
Code: [Select]
#include <SD.h>
File file;
    int c = f.read();
      line[n] = 0;
      return true;
    line[n] = c;
  while (*ptr) {
void setup(){
  long x, y;
    return;
  if (!file) {
    return;
    Serial.println(x);
    Serial.println(y);
void loop() {}
thanks that you've already post coding to read value from .CSV.. but I'm hardly to understand, because i'm new to arduino and C language..
could you give explanation..sorry if i'm really burdensome... :(
abinaustin
HI fat16lib
CAN YOU EXPLAIN HOW DID YOU USE POINTERS TO READ VALUE FROM SD CARD.ESPECIIALY*PTR ,IS THAT DEFAULT POINTER? I DONT UNDERSTAND THE CODE. CAN YOU BREIFLY EXPLIAN
THANKYOU
abinaustin
// easy program that reads csv file.
#include <SPI.h>
#include <SD.h>
File myFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // re-open the file for reading:
  myFile = SD.open("TEST.CSV");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      String a="";
      for(int i=0;i<9;++i)
      int j;
       char temp=myFile.read();
        if(temp!=','&&temp!='\n')
      { //a=temp;
        a+=temp;}
      else if(temp==','||temp=='\n'){
        j=a.toInt();
     // Serial.println(a);
      Serial.println(j);
      break;}
    // close the file:
    myFile.close();
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // nothing happens after setup
reads the values from file as string then converts to int, the ',' is used to seperate it .*/
CatweazleNZ
#8
Aug 08, 2015, 09:54 am Last Edit: Aug 08, 2015, 09:59 am by CatweazleNZ
Hi
I cannot say I like this as an example of a generic way to read CSV text files:
Code: [Select]
      String a="";
      for(int i=0;i<9;++i) {
        int j;
        if(temp!=','&&temp!='\n') {
          a+=temp;}
        else //if(temp==','||temp=='\n'){
          j=a.toInt();
          Serial.println(j);
      } //Only read eight characters from one line
    } //while (myFile.available())
    // close the file:
These two lines may fragment heap memory with tiny unused old strings - one 1 byte, one 2 bytes, etc.
Code: [Select]
      String a="";
      a+=temp;
And this seems an unnecessary way to process individual lines - also each line cannot be longer that eight bytes.
Code: [Select]
This untested code might be a better generic algorithm for loading of CSV text files:
Code: [Select]
//Easy program that reads a csv file
//Parsing comma separated fields
//We assume all the fields on each line are integers
#include <SPI.h>
#include <SD.h>
  while (!Serial) {
  if (!SD.begin(4)) {
    return;
  File myFile = SD.open("TEST.CSV");
  if (!myFile) {
    return;
  String l_line;
  l_line.reserve(128); //Avoids heap memory fragmentation
                       //Reserve space for your longest expected data line
    l_line = myFile.readStringUntil('\n');
    l_line.trim();
    if (l_line != "") {
      int l_start_posn = 0;
      while (l_start_posn != -1)
        Serial.println(ENDF2(l_line,l_start_posn,',').toInt());
    } //skip blank (NULL) lines
  }//Read the file line by line
  myFile.close();
} //setup
//EXTRACT NEXT DELIMITED FIELD VERSION 2
//p_start increments as we move along the line
    return "";
    p_start = l_index;
Cheers
Catweazle NZ
fat16lib
rkn2008
#10
Nov 15, 2015, 07:18 pm Last Edit: Nov 15, 2015, 07:19 pm by rkn2008
Code: [Select]
#include <SD.h>
File file;
    int c = f.read();
      line[n] = 0;
      return true;
    line[n] = c;
  while (*ptr) {
void setup(){
  long x, y;
    return;
  if (!file) {
    return;
    Serial.println(x);
    Serial.println(y);
void loop() {}
This is exactly what I need but I have 3 variables.
How could I modify this to handle 3 or more variable???
fat16lib
Here is an example that reads a CSV file into an array with any number of columns/rows.
Code: [Select]
// Example to read a two dimensional array.
#include <SPI.h>
#include <SD.h>
#define CS_PIN 10
// 5 X 4 array
#define ROW_DIM 5
#define COL_DIM 4
File file;
 * Read a file one field at a time.
 * file - File to read.
 * str - Character array for the field.
 * size - Size of str array.
 * delim - String containing field delimiters.
 * return - length of field including terminating delimiter.
 * Note, the last character of str will not be a delimiter if
 * a read error occurs, the field is too long, or the file
 * does not end with a delimiter.  Consider this an error
 * if not at end-of-file.
size_t readField(File* file, char* str, size_t size, char* delim) {
  char ch;
  size_t n = 0;
  while ((n + 1) < size && file->read(&ch, 1) == 1) {
    // Delete CR.
    if (ch == '\r') {
      continue;
    str[n++] = ch;
    if (strchr(delim, ch)) {
  str[n] = '\0';
  return n;
#define errorHalt(msg) {Serial.println(F(msg)); while(1);}
  // Initialize the SD.
  if (!SD.begin(CS_PIN)) {
    errorHalt("begin failed");
  // Create or open the file.
  file = SD.open("READNUM.TXT", FILE_WRITE);
  if (!file) {
    errorHalt("open failed");
  // Rewind file so test data is not appended.
  file.seek(0);
  // Write test data.
  file.print(F(
    "11,12,13,14\r\n"
    "21,22,23,24\r\n"
    "31,32,33,34\r\n"
    "41,42,43,44\r\n"
    "51,52,53,54"     // Allow missing endl at eof.
  // Rewind the file for read.
  file.seek(0);
  // Array for data.
  int array[ROW_DIM][COL_DIM];
  int i = 0;     // First array index.
  int j = 0;     // Second array index
  size_t n;      // Length of returned field with delimiter.
  char str[20];  // Must hold longest field with delimiter and zero byte.
  char *ptr;     // Test for valid field.
  // Read the file and store the data.
  for (i = 0; i < ROW_DIM; i++) {
    for (j = 0; j < COL_DIM; j++) {
      n = readField(&file, str, sizeof(str), ",\n");
      if (n == 0) {
        errorHalt("Too few lines");
      array[i][j] = strtol(str, &ptr, 10);
      if (ptr == str) {
        errorHalt("bad number");
      while (*ptr == ' ') {
        ptr++;
      if (*ptr != ',' && *ptr != '\n' && *ptr != '\0') {
        errorHalt("extra characters in field");
      if (j < (COL_DIM-1) && str[n-1] != ',') {
        errorHalt("line with too few fields");
    if (str[n-1] != '\n' && file.available()) {
      errorHalt("missing endl");
  // Print the array.
      if (j) {
        Serial.print(' ');
      Serial.print(array[i][j]);
  file.close();
rkn2008
im sorry i just cant follow.
I can be clearer i guess or maybe im just retarded.
I have a CSV file with 3 pieces of data.
with an ever changing amount of rows.  The columns will always be 3 (date_time, lat, lon)
I need to read that file from LOG.CSV to the variables of date_time lat and lon so i can put them in a POST statement and have them sent to a PHP web-server as:
log.php?date_time=date_time&lat=lat&lon=lon
Does this make sense??
Please let me know what you think.  i am just stuck in this rut.
NewbieNewbie
Thanks for multirow, multicolumn read code.
I am trying to modify so that it ignores the condition of too few fields.  I have designed file data structure to have variable columns.
I will continue to try and hope to get it working before you reply.
xiaoyan1994
Hi fat16lib. How can I read six decimals places from files instead of integrals by using your code?
