Capacitative sensing relies on you changing the capacitance (by changing the dielectric value) between two plates. One of those plates is an analogue input, and the other is ground. Yes, it is possible (though wrong) to use the earth as the ground plate, but you should really have two plates on your PCB layout, and you measure the capacitance between them.
It sounds like you're doing it the lazy way and only having one plate in your design and relying on the ground being the other.
