Topic: Digital Spirit Level? (Read 3072 times) previous topic - next topic
zooto68
Anyone any idea how to make a digital spirit level? Can an accelerometer be used or does that need a lot of movement to activate? Any other ideas please?
macegr
With a +/- 1G accelerometer, you can directly measure tilt in reference to gravity. You would likely need some precision op-amps and a lot of software filtering to get accurate results to less than a degree.
An interesting way to implement this would be a two axis accelerometer with a small graphic LCD; a dot on the LCD would show where the device was tilted in two axes. Perhaps you could set a desired angle and the microcontroller could beep when that angle was achieved, allowing one person to position an object without looking at the device.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
mem
#2
Oct 20, 2008, 07:35 pm Last Edit: Oct 20, 2008, 07:36 pm by mem Reason: 1
One could probably simulate a bubble level using a 16 character based LCD.
And this thread described how to use  custom characters to get a higher precision vertical display, a similar technique could be used to increase the horizontal resolution to +- 64 units of tilt.
And of course there is a graphics LCD library in the playground  ;)
Sounds like a fun project.
zooto68
PixelFreak
Apparently you can buy sspirit level software for an iphone
zooto68
I don't have an iPhone. I have an Arduino.
