Topic: [Solved]Measure a battery amps (Read 8589 times) previous topic - next topic
jbarchuk
So by this, tell me what's the best way to charge a lipo battery.
The way the -battery- -manufacturer- says to, for the part number printed on the battery. Wikipedia lists 24 different 'lithium' chemistries. Lithium is the family name -lithium ion and lithium polymer are not necessarily synonyms. Voltages and charge/discharge characteristics vary *DRASTICALLY*.
I've followed this topic: http://forum.arduino.cc/index.php?topic=230870.0
Do you think i'm ok with that?
That looks like the straight dope.
CrossRoads
MAX1811 is easy to use for a LiPo.
Here I used one to charge a 1000mAH LiPo in my RF remote control.
I used 3AA battery pack for development, then connected the LiPo when I get the other parts in.
Has been running since ~Jan 2011.
tsunamy_boy
Why  :smiley-roll-sweat:
Do you have the need to setup resistors based on the amps that your batteries have?
CrossRoads
No. Lower left resistor is there to set Enable High or Low depending on whether external power is available. Upper right resistor is there to limit current to the charge indicator LED for brightness control.
Pins 1 & 2 determine whether it charges to 4.1V or 4.2V, and at 100mA rate or 500mA rate.
tsunamy_boy
The IC does that automatically?
(...) at 100mA rate or 500mA rate.
This means that i can't charge a battery bellow 100mA or above 500mA?
retrolefty
Yes, and yes.
CrossRoads
Yes, the chip controls the level.
100 & 500mA are the rates supported by this chip. USB as the current source.
I suppose if the source can't supply that much, it will use whatever is available.
tsunamy_boy
Yes, and yes.
Thank you :)
Thank you, is there any other chip like that that can handle until 1Amp?
CrossRoads
Don't know. Search "battery management" at www.maxim-ic.com
or www.maximintegrated.com
My chrome is having a hard time connecting to maxim right now for some reason.
CrossRoads
This will do 1A, need to have the exposed pad connected for cooling.
http://www.digikey.com/product-detail/en/BQ24090DGQT/296-25863-1-ND/2237301
tsunamy_boy
If i understood it charges batteries at 10mA min and 1000mA max right?
What does this means: "Pin Selectable USB 100mA and 500mA" cuz i'm confused about this
CrossRoads
Read the Pin Functions on page 7:
ISET2, pin 7:
Programming the Input/Output Current Limit for the USB or Adaptor source:
High = 500mAmax,
Low = ISET, (another pin, see below)
FLOAT = 100mA max.
ISET, pin 6:
Programs the Fast-charge current setting. External resistor from ISET to VSS defines fast charge current value. Range is 10.8k (50mA) to 540 ? (1000mA).
Also read more about these 2 pins on pages 18, 19.
tsunamy_boy
ISET2, pin 7:
High = 500mAmax,
FLOAT = 100mA max.
ISET, pin 6:
And i have to calculate a resistor to different battery amps right?
retrolefty
ISET2, pin 7:
High = 500mAmax,
FLOAT = 100mA max.
ISET, pin 6:
Yes
tsunamy_boy
humm then i already have similar to that =)
I would go with a charger that doesn't need changes :P
