Topic: Controlling Automower (Read 42312 times) previous topic - next topic
Dawiinci
Problem happens if Automower has low battery. So I have to restart Arduino because it is probably not an issue of the code. How can I do this?
pylon
Change
Code: [Select]
if (strcmp (buffer, "digital") == 0)
to
Code: [Select]
if (strcmp ((char *)buffer, "digital") == 0)
and it compiles for me.
Quote
What happens if the mower is low on battery? Does the voltage that powers the Arduino drop? How much voltage do you have with a full battery? How much if it's getting empty? Where do you feed the Arduino with this voltage (Vin, 5V, power connector)?
You can restart the Arduino by pushing the reset button. You probably meant how to do it in software: that doesn't make sense because your software is already not running correctly, so don't expect it to reset itself.
Dawiinci
I can read the Sensors so the issue might be in the Automower side.
But I will try your code thanks.
pylon
Quote
Why do you want to restart the Arduino then? What do you expect that this should fix?
Dawiinci
#34
Jun 13, 2014, 11:18 pm Last Edit: Jun 14, 2014, 10:52 am by Dawiinci Reason: 1
I can only guess, but it might be possible that the Automower gives feedback that has more than 5 Bytes and therefore I have the issue. In that case the script is not in sync anymore.
However I have a new issue with your code:
Code: [Select]
I can readSensor (humidity) only if I never call doCommand or digital, analog. After I call anything else than readSensor it returns nothing anymore until restart.
Code is attached.
pylon
Quote
That's no reason to reset the Arduino. If you're unsure clear the serial buffer from time to time.
Quote
Why do you think this has anything to do with "my" code?
Your code formatting is still horrible. Please take the time to use the AutoFormatter in the IDE at least.
Although it should make a significant difference, change the code
Code: [Select]
#define BUFFERSIZE 40
uint8_t buffer[BUFFERSIZE];
uint8_t i = 0;
while (i < BUFFERSIZE) {
  if (client.available()) {
    uint8_t c = client.read();
    if (c == '/') break;
    buffer[i++] = c;
to
Code: [Select]
uint8_t i = 0;
    buffer[i++] = c;
if (i < BUFFERSIZE) buffer[i] = 0;
In digitalCommand() and analogCommand() you're still using the String class. Why?
Dawiinci
Thanks it works for now. I will report back if it happens again.
Well I have another project, maybe you can give me a hint as well:
http://forum.arduino.cc/index.php?topic=248344
Samino
Hello Dawiinci,
Great project you did! I own the same automower and was looking for exactly this. How is it working for you now?
Do you have this project documented somewhere, or would you like to post the code and instructions?
That would be awesome  :)
Thanks
Sam
sledgehammer
hi dawincii
i am also interested in the whole project description
off course with a please and thank you
mario
pagix
Hi dawincii,
this seems to be quite interesting, because iown a 220 :)
So I am also interested in the whole project.
Greetings
mike
Samino
Hello,
also intrested!
kr
Sam
