Topic: atmega328P on 1.8v (Read 3955 times) previous topic - next topic
aballen
Mar 02, 2009, 02:37 am Last Edit: Mar 02, 2009, 03:00 am by aballen Reason: 1
I was just going over the 328P datasheet, and its says it can run at 20mhz on 4.5-5.5V... makes sense for the arduino at 16mhz to require 5V
If I choose to run arduino at 1mhz, I can run it down to 1.8Vand only .3ma power consumption.
What is the mA for arduino at 16mhz?
Why?  I'm trying to build a small battery powered device, device that automatically powers down after 1 hour.  I would like to run it on 2AA batteries, since there is much more mA available, the batteries should last longer... and I'm wondering if the power savings for running at 1mhz... is really worth the trouble.
or should I try an attiny43U...
westfw
There are two philosophies about keeping low power consumption.  Certainly lowering the clock rate lowers the power consumption, but the other idea is to have the processor spend most of its time in low-power sleep modes, then wake up periodically and run at high speed so you can get back to to low-power sleep mode as soon as possible...
aballen
Well by device has 12smt leds on it, so I'm thinking the power usage of the atmel168P will be small compared to the leds power consumption... and after an hour I power everything off...
Can I put the device to sleep, with the leds on, and have it automatically wake up after an hour... then shut everything down... and then powerdown until it is reset?
Is it worth the trouble?
trialex
I say do your prototyping on the arduino, then port to a smaller device for the final version.
I was doing a project with the same goal as you, and looking at the datasheets for the '168 and the AtTiny2313, the consumption of the '168 in one of the sleep modes (there are a few) was equal to the full-speed running consumption of the '2313.
So yeah if you can move down a device or two (attiny4X as you suggest) you also get significant power savings.
pjrc
Yes, it's worth it, if you want long battery life.
But for an intermittent use like you're describing, the biggest savings comes from the complete powerdown mode where you've shut off all the LEDs.  That is the one you want to focus your efforts on, usually with a current meter connected.  If the brownout detector is enabled but everything else if stopped, you should have about 30 uA current.  It's very easy to find something else besides the processor is using a lot of current.  For example, a 7805 voltage regulator uses 4 mA all the time.  Running directly from the battery without a voltage regulator saves that!
When you are running, keeping the current low helps if you spend a substantial amount of time in on mode.  But also a big improvement comes from being able to run on a lower voltage.  Especially for alkaline batteries, the voltage declines gradually as the batteries die, from 1.5 volts to 1.0 volt.  So if you can still run "normally" on 2 volts, you'll get a lot more life out of the batteries than if you can't run when they fall below 1.3.
Probably a difficulty you'll have running down to lower voltages is being able to turn those LEDs on.  Red LEDs usually need 1.8 volts minimum, green about 2.1 volts.
So to put some numbers on all this, first a AA battery has about 2500 mAH capacity.  That's a rough guess, maybe it's more if you run all the way down to 1.0 volt per cell.  Suppose while you're running, current consumed is 30 mA.  That's enough to run on about half of those LEDs with 4 to 5 mA and run the processor.  Suppose power down current is 0.1 mA, which is not too hard if you've carefully checked nothing else is hogging current when you're in full stop mode.
Suppose your board gets used 4 times a day, each time staying at 30 mA for an hour.  That's 120 mAH of the battery.  The powerdown runs the other 20 hours at 0.1 mA, consuming 2 mAH of the battery.  Using 122 per day, you should last about 20 days.
In this case, using less current in the LEDs or shortening that powerdown timeout (assuming the user isn't actually using it for all 4 hours) buys you a lot, since active mode is burning 122 mAH every day.
It's also pretty easy for the powerdown mode to burn too much.  I just picked 0.1 mA, which is doable if you're careful.  But look in another thread where someone reported their board was about 9 mA in powerdown mode (clearly something else on the board was burning the current).  That would put the powerdown at 180 mAH per day.
This simple math assumes, of course, the current is always constant in both modes, which is usually approximately the case.
aballen
wow, so I think I'm better of running on 2AA batteries, vs 3AAA batteries then?
I just have to worry about clock speed, since I want the device to power off after one hour. I think there is a sticky on running the arduino at 1mhz somewhere.
