Topic: [HELP]Ultrasonic sensor and motorShield. (Read 897 times) previous topic - next topic
TheDigitalToaster
Apr 15, 2014, 10:59 pm Last Edit: Apr 15, 2014, 11:07 pm by TheDigitalToaster Reason: 1
It is reading the data, I am able to connect to it trough VB.NET. But nothing happens.
Thanks in advance.
Code: [Select]
// Declarations
#include <SPI.h>
#include <Ethernet.h>
// Wired configuration parameters
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xD1, 0x4B };
unsigned char local_ip[] = {192,168,1,5}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
int E1 = 8;
int M1 = 9;
int E2 = 6;
int M2 = 7;
const int trigPin = 12;
const int echoPin = 13;
EthernetServer server(80);
//char buffer[20];
String buffer = "";
 pinMode(M1,OUTPUT);
 pinMode(M2,OUTPUT);
 Ethernet.begin(mac, local_ip);
 long afstan;
 afstan = afstand();
 if (client)
   boolean currentLineIsBlank = true;
   while (client.connected())
     if (client.available())
       char c = client.read();
         if (afstan < 10)
           Serial.print(c);
               analogWrite(E1, 0);   //PWM Speed Control
               analogWrite(E2, 0);   //PWM Speed Control
     else {
       switch (c) {
         case 'v':
                 digitalWrite(M1,HIGH);
                 digitalWrite(M2, HIGH);
                 analogWrite(E1, 255);   //PWM Speed Control
                 analogWrite(E2, 255);   //PWM Speed Control
         case 'a':
                 digitalWrite(M1,LOW);
                 digitalWrite(M2, LOW);
         case 'r':
         case 'l':
         case 's':
long afstand(){
 long duration,cm;
 pinMode(trigPin, OUTPUT);
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 pinMode(echoPin, INPUT);
 duration = pulseIn(echoPin, HIGH);
 // convert the time into a distance
 cm = microsecondsToCentimeters(duration);
 Serial.print(cm);
 Serial.print("cm");
 return cm;
long microsecondsToCentimeters(long microseconds)
 // The speed of sound is 340 m/s or 29 microseconds per centimeter.
 // The ping travels out and back, so to find the distance of the
 // object we take half of the distance travelled.
 return microseconds / 29 / 2;
PaulS
Quote
What is?
Quote
How?
Quote
And the problem is?
How are we supposed to know what you are asking the server to do? How are we supposed to know what the server actually does?
Code: [Select]
          if (afstan < 10)
            Serial.print(c);
      else {
        switch (c) {
          case 'v':
You get the prize for crappiest indenting today. Congratulations.
Now, go learn what Tools + Auto Format does.
