Topic: help with a pulldown (Read 1 time) previous topic - next topic
aballen
I made a circuit in eagle and after patiently waiting for it to come in the mail I found out I screwed up a part of the circuit.  I think I have it fixed, however I'm worried I will send it back out... wait 4 more weeks, and get another bad circuit back in the mail.  so I was hoping I could get some feedback.  I can make this work on a breadboard no problem... but seem to be having trouble in eagle.  So here is a pic.
On the bottom right I have vcc going to a pin through a resistor(actually pin 2 on my arduino)  the pin is supposed to be set to high, when I push a button that is connected off board to the 2 pin header, the pin should go low.
Did I get it right this time?
nkcelectronics
#1
Mar 17, 2009, 03:33 am Last Edit: Mar 17, 2009, 03:34 am by nkcelectronics Reason: 1
No, you will create a short circuit GND - VCC
You need to connect the pin from the switch on the other side of the resistor R13
bohne
yes move R13 to the other side, so right to JP4. And what is the value of R13?
http://www.dorkbot.de
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236434254
http://www.luminet.cc
aballen
like this?
This is how I had it before, and it is always low... high when I push the button (shorting jp4)  is it possible I just put in a resistor of too high value?
The arduino pin is being used as an input, in case I wasnt clear.
trialex
Quote
The only way that could happen is if the button is NORMALLY closed, and when you push the button it OPENS the circuit. Either you've got a different switch to what you were thinking, or you've got the wrong legs wired up.
The second schematic is what you want. You could of course change the logic inside your program so that a LOW means not pushed and HIGH means pushed.
aballen
hrm... a bad switch eh?  I'll have to check that.  did not occur to me.
I need it to be HIGH, and pulled low on button press... that how the SLEEP_MODE_POWER_DOWN interrupt works... it has to pull down.
Thanks
trialex
Oh ok cool.
It's not so much that it's a BAD switch, it just doesn't operate exactly the way you first thought
If you are using one of those little 4 legged tact switches, you might have picked two of the legs that are normally closed. If you pick two legs that are diagonally opposite, they should be normally open when the button is not pushed and closed when it is pushed
anachrocomputer
#7
Mar 17, 2009, 11:35 am Last Edit: Mar 17, 2009, 11:37 am by anachrocomputer Reason: 1
Do you have a multimeter?  If so, you should start by testing the switch (with power off, measure Ohms), and then check the voltage on the input pin (power on, measure Volts).
And could you please tell us the value of the resistor?
aballen
wow!!! you were right... the switch is closed, and open when I push the button, exactly the opposite of what I wanted.  This means the boards I made are correct, yay!!
I have the boards though, so I need to get a new button switch rather than change the circuit.  Thanks a bunch guys.
